Advertisement
Sold: GT Base to Sync 3 Swap 15-17 GT/EB/V6 - DIY Kit
Spart
Posts
1,115
Iowa
17 GT350
SOLD
WILL NOT WORK WITH GT350.
These are the Sync 3 components that I removed from my 17 GT Base before I traded it. It's everything you need to convert a base Sync system (with the calculator buttons) to Sync 3, including CarPlay and Android Auto. This is a non-nav APIM and cannot be upgraded to factory nav without substituting a nav APIM. However, you'll be able to use Google Maps etc. through CarPlay and/or Android Auto, which is exactly what I do with my GT350 that came with factory nav.
PLEASE NOTE THAT THIS IS NOT A PLUG AND PLAY KIT:
I cannot emphasize this enough. If you buy this and throw it in your car, it will not work. In order to install this kit, you need to:
  1. Have a working knowledge of how to change your as-built data using FORScan. You will need a Windows PC, an appropriate adapter such as an ODBLink MX Bluetooth, and the FORScan software with an extended license. For full functionality, you MUST update the as-built in your Body Control Module, ABS Module, Instrument Panel Cluster Module, and Audio Control Module. You must also customize the as-built in the APIM included in this kit to match your car.
  2. Be comfortable modifying your factory harness. You will need to re-pin the connector for the APIM and relocate pins from your GPSM connector and base camera connector to the APIM connector. Instructions on how to do this are here.
That said, you can skip step two buy purchasing a plug and play harness from @HextallS550 here: https://www.harnessbyhextall.com/products/pcorrtsi1ia6klzqiif4s716c7jvrs
Included in this kit are unopened WT-1000 and WPT-1239 Ford harness repair kits to be used for the DIY procedure described in step two above.
This kit has the two-port Sync 3 hub. You would leave your factory USB routing intact, plugging the wire with the gray connector into the gray port on the APIM and same for the black connector/port. Your front port at that point will be charge-only, and you'll have two data/CarPlay/AndroidAuto capable ports in the center console utilizing the included USB A to Mini USB cable.
The components of this kit (except the aforementioned Ford harness repair kits) are used but in great shape. There are some tiny scratches on the screen that are only visible in the right light with the screen off. The HVAC panel has some very tiny blemishes as well. Just normal light use, nothing that you're going to notice without looking for it.
I will not be providing tech support for this swap as I simply don't have the time, but I will provide all of the links on this website to posts with info on how to do it. Additionally, if you purchase a harness from Hextall, you will have access to programming support. That's not to say by purchasing a plug and play harness that you can skip getting a Windows Laptop + Adapter + FORScan w/Extended License, you still need to do all of those things.
I am asking $900 plus actual shipping for this kit. This all ships in a 19x15x7 box weighing 8 pounds from 50140 if you would like to get your own quote and/or provide a label. If you do provide your own label, I request that you ship UPS only and insure to the full value. I will do the same if I purchase the label on your behalf.
Pics:
HextallS550
Gold Sponsor
Posts
1,067
Dearborn, MI
2017 GT
I get what your saying but Infotainment isn't sponsoring this board or supporting anyone here.
Sorry to dirty up the thread Spart.
AzSideWinder
Posts
Arizona
Joe
2017 Mustang GT
Please keep that BS out of Spart's thread. Infotainment is overpriced Chinese crap.
I posted it because of the install process and to show the value..
and the site your blasting is also
  • Genuine Ford 8-inch Capacitive Touch Screen Display
Advertisement
Spart
Posts
1,115
Iowa
17 GT350
Agreed on the overpriced, but their how-to on taking the dash apart may be useful.
HextallS550
Gold Sponsor
Posts
1,067
Dearborn, MI
2017 GT
Its really all I was trying to do since you said you wouldn't provide support. Sorry to piss people off.
Did you see my reply after his post?
Over the years Spart has helped us all out tremendously I will offer a harness at dealer price to the buyer as well as the correct as built data.
I agree it's a good deal and I offered to make it a better deal. I see what you're saying though. Too many times people try and get into peoples for sale threads and undermine them.
Advertisement
Advertisement
Advertisement
