I used chyrsler small license plate holders from Ace hardware@Dutch44 what did you use for the 3" upper speaker to bolt the speaker mount to the door? I have 3 square holes there with nothing in them and I'm trying to figure out how to run a bolt or screw through the mount into the door.
Don't bother ! I just used the molex connectors and 18 awg , the system is perfectly fine with 18 and I tossed the 30 ft of 14 awg I had in the top tool box drawer it fits better there then in the mustang ..Thank you, that helps tremendously...next task is getting my 14awg into the door somehow...not going to be easy.
You went way further than me. I'm going with zero speakers in the rear except sub in trunk. Really cool how you did the rear tweets and that amp mount is way cool. My amps and dsp are mounted on a board in the spare tire well with a cutout for the tire inflation kit. Ran 0/1 power through the firewall (like everyone) and ran it up the right side of the car next to the center console, speaker wires up the right passenger and left side...now just need to feed into a-pillar and doors. My sub is NOT a JL stealthbox...its made from layered resinated wood cut on cnc (not my machine). Can be had from an audio place in jacksonville florida and they ship. I'm doing the sync 3 conversion and I bought used door cards with the top speaker grill. Here's what will be in the trunk...
What's really cool is that white funnel peice there ! I bought two for the octane boosters and saw that and was aww struck ..You went way further than me. I'm going with zero speakers in the rear except sub in trunk. Really cool how you did the rear tweets and that amp mount is way cool. My amps and dsp are mounted on a board in the spare tire well with a cutout for the tire inflation kit. Ran 0/1 power through the firewall (like everyone) and ran it up the right side of the car next to the center console, speaker wires up the right passenger and left side...now just need to feed into a-pillar and doors. My sub is NOT a JL stealthbox...its made from layered resinated wood cut on cnc (not my machine). Can be had from an audio place in jacksonville florida and they ship. I'm doing the sync 3 conversion and I bought used door cards with the top speaker grill. You can see the speaker wire to the left from the drivers side...very thick and almost bonehead to get that, hence my dilemma running them into the door...only option might be to drill a hole. Here's what will be in the trunk...
