xr4x4ti
Minnesota
Tim
AWD 2017 Mustang GT 6MT Supercharged.
What about the 3.73 gears and the front limited slip?
I have not driven it enough yet to get a valid opinion the gear ratio change. But I think I may like the 4.09 a bit better, but I am not in a hurry to swap back.
What is noticeable is the front Truetrac has made it a bit more "darty" under throttle. Not in an unacceptable way, but noticeable. It is hard to explain, but one of the huge advantages of the AWD is unlike traditional Mustangs you can floor this thing in the middle of a turn and it just goes with very little drama. It still does that, but I think it added a bit of understeer as the front diff tries to lock up a bit. It is early, I will see how it goes. It is an interesting experiment for sure.
Tim
zenwhipper
Seattle
Scott
2023 Mach 1
Yesterday we put it up on the lift and ran it up to speed. We then just felt around to try and figure out where the vibration was coming from. It seemed pretty obvious that it is the rear differential. When touching the rear differential while at "speed" there was a serious rhythmic vibration.
My grand dad was a mechanic in Iowa for 50 years. He'd take a crow bar or screw driver, place the handle end to his ear tight and the other end to a part he may suspect was causing issues. Works great for spinning components and vibes.
The doctor is in
1 old racer
Fontana CA
Will
The doctor is in
My dad gave me one of these over 50 years ago and I used it on my gt in order to tell if I had the dreaded tap on my 2018. with it I could tell it was coming from the high pressure injectors
Buldawg76
Alabama,USA
2020 Ecoboost Premium, 76 FXE shovel, 77 KZ1000
Been using the screwdriver stethoscope trick for 50 years.
BD
xr4x4ti
Minnesota
Tim
New Episode is out, covering how the AWD tcase works and the Syvecs AWD controller.
xr4x4ti
Minnesota
Tim
Some progress, engine is out to get a new short block.
xr4x4ti
Minnesota
Tim
American GTr gets a New V8 Short Block - AWD Mustang Ep 32 Ford Aluminator Coyote Supercharged.
xr4x4ti
Minnesota
Tim
With a bit of creativity I got the GT500 manifold to fit a standard coyote head.
