DAZZA
First ever post. Brand New Mustang GT in Australia.
Love the car but the Audio is a huge letdown. This is the premium 9 speaker system.
my first mod is to get the audio sorted before messing with the rest of the car.
I have read almost every thread in this forum and done some fiddling of my own.
I installed a amplifier in my spare wheel well, replaced the rear parcel shelf speakers with woofers and ran the high level signal from the rear output of the factory amplifier to the new amplifier. I knew this was not going to work but I needed to clarify for myself that the information on this forum was correct as there is so much conflicting information. It improved the sound tremendously, my speakers seem to produce some decent bass response, despite not being subwoofers but the plan is to not use rear speakers and only have a subwoofer in the trunk running off this amplifier. These woofers will the transferred to the front Doors once I have sorted out the ACM and DSP issues.
To confirm whats been noted on the forum.
The Rear signal from the factory amplifier manages to produce some low frequency but the noise cancellation interferes with this when the car is running. I am not sure when the engine is off if the full range is there or not, this full range I believe can be tapped off the front speaker signal.
I could take the high level signal from the front speaker output but the noise cancellation is still going to be a problem. This needs to be sorted first.
If you unplug the microphone that listens for the noise will this not introduce road noise into the car? I cannot find anyone who has experimented with this and reported the findings?
I could take a preamp signal from the output of the ACM. I could remove the factory DSP and amplifier all together but I am concerned about what the car will sound like without noise cancellation and any potential sound enhancements.
The other issue is that appears the louder you turn the volume up the audio has been shaped by the ACM (Headunit) this is supposedly designed to prevent damage to the $2 speakers. Which means keeping the existing factory amp and replacing the speakers is not going to fully recognize the potential of the new speakers.
So one needs to use forscan and change the hex code to allow for a flat response without shaping.
I am thinking of unplugging the output and noise cancellation plug from the ACM and drive the car without the noise cancellation circuit and potential sound enhancement.
If this proves to not make a difference then maybe the best way to resolve the audio issues is the following:
Make a wiring harness for a new amplifier with pre amp ouputs, remove the existing factory amplifier use forscan to program a flat signal.
appreciate anyone information regarding noise cancellation and sound enhancements, who has removed the factory DSP/amplifier all together and does not appear to have any issues with the road noise or lack of fake noise (which may not be in the GT anyway)
Sorry for the long post.
