At what HP should one sleeve their 5 liter? Any benefits of sleeving if not going over 1000whp?
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
I am having a block built I will stay under 1000WHP is there any benefit of sleeving a that power level? Also how much extra would that cost on average?
engineermike
La
2018 GTPP A10
I honestly don’t see any advantage to sleeving a coyote block vs using a stock predator block that costs less than $2k and can be assembled as delivered with no further machine work.
Unas2k5
Unas2k5
Detroit
Samer
They said they were going to send out my block & the cylinder heads I sent them to get redone. I was just wondering if I should tell them to sleeve it or not but I guess its not worth it
Kennysum1
Huntsville, Alabama
Kenny
2017 Alfa Romeo Quadraflio, 2018 TT GT Prem, 22 GT
Don't even need a "built" one for those power levels. A good old 5.0L with oil pump gears will handle it just fine.
Sleeving is not needed until 1200++
Jackson1320
California
Jaxson
2015 mustang gt
to sleeve is around $2500-$3500 so I agree with mike you can get a block that is ready to be built for a lot less. for $1900 get a 3.7 bore block or for $900 get a new stock block.
illtal
Don't even need opg to run under a 1000. I wouldn't even entertain the idea of sleeving or upgrading the block in any way.
Predator block will get you to 1300+
a sleeved coyote is 1500+
a sleeved predator is 1800+
WIST2019GT
Madison
2021 Mustang GT
Can you put gen 3 DI heads on the predator short block in a gen 3 coyote? Seems like it could be a good/cheap alternative to a rod and piston build.
illtal
Yes this is what I have but I have a predator crankshaft as well.
The normal would be to run a coyote crankshaft to mimick the gen 3 clearances.
The predator crank is different and it has slightly more stroke.
engineermike
La
2018 GTPP A10
@illtal what pistons are you running?
I have a stock Gen3 short block and a stock predator short block. I’ve been debating on whether to use the predator as is or with a stroker crank and slightly more compression.
I’d love to know how a gen3 top end, predator bottom end, and a supercharger work together.
engineermike
La
2018 GTPP A10
afaik you can, just have to use the gen3 head gaskets. Problem is a new predator from ford is a bit pricy ($7500 plus core plus shipping)if you can find a dealer willing to sell you one. The block and crank are cheap-ish, but the pistons, rods, and rings aren’t. Even still, it looks like you can piece together a stock predator short block for about $6000 using all new ford parts, which isn’t so bad I guess. To me it’s a way stronger option than aluminator for not much more money.
illtal
I'm using a tkm short block predator crank boost line rods, wisco pistons. 12:1. Heads will be ported by Frankenstein. Rev limit 8500. I have posts in the build thread. I will likely be turbo after it's all said and done.
I will also be using either the SCE head gaskets or a custom thickness because the oem predator is not thick enough on this combo.
If you have the 9.5 compression I'm sure you can make way more boost.
You can use a stoker crank but I would rather have the RPM of the stock crank.
I would throw some 10.5:1 pistons in it. TKM offers those now for coyote, voodoo, and predator. If they had those when I ordered many months ago I would have taken those.
On a side note now much dome does the stock gen 3 have is it 7cc?
Unas2k5
Unas2k5
Detroit
Samer
That looks so damn good
Barrel
Hoonigan
Cars and Trucks
I have a TKM block with Darton sleeves. Sleeving only added $750 when I built mine a couple years ago. I'm sure like everything it's more now but I thought it was a no-brainer.
200 - Redline360 - 1
