K4fxd
Sure makes it a lot easierignore the 20 ton press
so would a lift but most people don't have em.Sure makes it a lot easier
just so people know, i have zero additional bracing and zero wheel hop and the car hooks.If you dont have other rear suspension bracing, then Steeda is right, just doing their sphericals wont add NVH. If you have a bunch of braces and supports added YMMV.
I went with Steeda, I definitely needed a press, like there was no way some ball joint press would have done it... So depending on your choice I wouldn't ignore the advice of having a press available.the first of the new ones slipped right in. I'm talking ZERO effort, no wiggleroom, just absolute perfection. the second required a little bit of force, i used a long bolt with a nut to gently encourage its cooperation.
my advice was specifically for the FTBR parts which are comparable in cost and vastly superior in terms of quality and easy of install.I went with Steeda, I definitely needed a press, like there was no way some ball joint press would have done it... So depending on your choice I wouldn't ignore the advice of having a press available.
Uncertain. Probably fine and worst case removing the cradle supports would probably do the trick if you do get more NVH than you like.Right now I have their steeda tri point brace for the rear suspension, the irs bushing support system and alignment kit. Is that enough bracing that the spherical bushings would cause NVH?
Maybe it's easier to do a low milage LCA?.....anyway I doubt I will have an issue with meagre 330 HP and no drag or race mode use.wrong
removing the LCA and the old bushing is the hardest part. ignore the 20 ton press comments. if you have one its nice to get the old ones out but you won't need it to install.
getting the old ones out is the hardest part. cut out the cores with a hole saw and with then slit the sleeves so i could hammer the rest of the carcass out.
zero NVH increase and the car hooks and books like a mother flipper now.
Low mileage didn’t matter when I did mine. I had 472 miles on my car at the time.Maybe it's easier to do a low milage LCA?.....anyway I doubt I will have an issue with meagre 330 HP and no drag or race mode use.
Tear out?Forg
I bought a 12 ton shop press specifically for this job and quickly bent the press ram on it and the factory bushing sleeve didn’t budge one bit. I ended up taking it to my buddy’s shop and he used his 20 ton shop press to finish the job.
Pics of the damaged press ram and repair needed to return my press to operational status.
If you’re asking whether my bushings tore out, the answer is no. I was able to use my press to push the rubber bushings and inner sleeves out, but when I moved on to press the outer shells out of the RLCAs, that’s when the press ram bent.Tear out?
almost certainly. a lot of it depends on how bad the roads are that you frequent.Right now I have their steeda tri point brace for the rear suspension, the irs bushing support system and alignment kit. Is that enough bracing that the spherical bushings would cause NVH?
