FreePenguin
edit I don't think its worth the time or money to buy new wheels.
+45 offset with a 20 mm spacer is 45 - 20 = +25 effectiveThank you for that info! I want to clarify
My 19x9.0 45 offset with 20mm with 255/40/19
Will have the same stance/position as
19x9.5 50 offset With 20mm spacer
And
19x9.5 30 with no spacer
All 3 of these options will keep the same exact positions currently? Because it’s perfect. Anymore will throw rocks and dirt onto car, and it looks flush to me. I put tire stuff on wheels, it would fling onto car if any further out too
I would like to use or get rid of the spacer either way doesn’t matter. I just really like it’s current stance. The current read pirelli p7 all season plus I just installed 2k miles ago. The rubber is not going anywhere
The concavity of the 9.0 in flat config is such that it can be milled anywhere from 18-51, while the deep is such that it can be milled back up to 46, and the 10.5" wide one starts at 18 and can go up to 64. If you're gonna custom mill (and why not) have them mill it to your end-state (25).It shows 2 options for 19, flat and deep, I like the deep look, but on the deep area it says.
19 x 9” Blank +18 to +51 Blank 0 to +46
The flat profile should have no problems clearing the front calipers. The Deep, could be trouble. If it was me, I'd buy the 10" wide with ET40 and then play with 3 and 5mm shims.
I think you're looking in the neighborhood of 400 a wheel.
Yes, just get them in +25. And 255 tire will fit on a 8.5 - 10" wheel, so no need to restrict your self to 9".But the largest they come in is 255/40/19 which is what I have now. If I got rid of my 20mm spacers, could I have the HF3's or HF1 to the same spot without spacers?
