valentinoamoro
My new wheels require a 5mm hub spacer to clear the wheel caps. This means there are approx 6 turns of the wheel lugs to hand tighten (around 7-8 to get it torqued right). I am using regular lug nuts. I will autocross next week.
Should I get extended studs? They are very expensive! (WTF) - around 300 for all 4 wheels!
Would extended thread lug nuts make a difference (much cheaper) - I'm not sure they just add more thread in the nut or actually can go deeper in..
Or should I remove the 5mm spacer and take off the wheel caps?
http://www.cjponyparts.com/ford-performance-wheel-stud-arp-extended-set-2015-2017/p/M1107C/
