honeybadger
Just don't care
Alright data from the cylinder head cooling mod test is in. To recap, I have water temp sensors installed in the back of both heads in addition to the OEM one (this one is not exposed to water). I then installed the MMR cooling mod with a ball valve so I could turn off water flow and data log the difference.
I went out and did a few laps with a ball valve closed, simulating the OEM configuration (no water "flow" between heads). Came in hot, turned the ball valve open and went out to see if it made a difference. It did - but not a statistically relevant one and not in the right direction. The delta between my heads actually got worse.
This is a bust, IMHO.
Session in full for transparency
Next, I tested my own cooling mod where I pumped "cool" water from the pump directly to the back of the cylinder heads.
I tested this in the next session. Even though I drove the car harder, got it hotter (check out oil temps), the heads ran cooler. Success! CHTs below 200 in a 25 min session in 80 degree ambient temps? WINNNNN
Full session for transparency. again
Some takeaways -
I'm also attaching my AIM Racestudio data files so you can dive into the data if you want
https://1drv.ms/f/c/8f6ab0808ad3acc2/EptpMgtSOkJJkm-xBzhbLSABfWcWkvQariG46ii2Nfzmuw?e=G8IByf
Some takeaways -
- my data logging on Saturday across 4 sessions showed that the cylinder head temps were always within 1-2 degrees of each other. This is a solution to a problem that doesn't exist, IMHO
- Sharing water between the two heads did not result in an improvement
- Supplying cooler water from the front to the back of the heads does yield improvements
