Anyone who's swapped/raised/messed with the accelerator pedal...
Konamoth
Atlanta, GA
Nick
2020 Mustang GT Base
...How the hell do you remove this cable?! I've tugged and messed with this thing for like 20 minutes and it feels like it's not even budging. The red clip is pulled back / raised.
I'm trying to swap in the aluminum pedals and raise the accrlerator, and after a fair bit of contortion, finally got the stock black pedal assembly removed, but now I can't get the cable loose!
PaddyPrix
San Diego
Patrick
2007 335is, 2018 Mustang GT, 2019 Hyundai Kona EV
Get a thin screwdriver and push that red tab back up and away from the accelerator, you'll feel it stop about 3/4 an inch later or so. Once that's backed out, you should be able to pinch/squeeze the flexible tab between that red tab and the harder and thicker plastic, and when pinched, just pull it away from the unit.
Konamoth
Konamoth
Atlanta, GA
Nick
Man, that's evil. I couldn't even tell there was a tab there!
In case anyone stumbles on this in future and needs a visual along Paddy's explanation:
Thanks man. You're a lifesaver. Now, back under the dash I go... 🄲
PaddyPrix
San Diego
Patrick
Yeah did all that wiring a while back and it's a pain... Be thankful you don't have an 8 point cage making it even more miserable under there.
Konamoth
Konamoth
Atlanta, GA
Nick
No kidding. I don't even want to imagine the pains that brings.
ORRadtech
Atlanta, Georgia
The thing is there are quite a few connectors that do that or something very similar. Rule of thumb, if you can't get a connector to come apart start looking for odd locking tabs...
That connector was probably engineered and designed by the same dude who thought it would be cool to put a cabin filter in the HVAC box facing the f'n kick panel... Instead of the filter location shooting straight out the front of the glove box . . . Like thousands of other SMART designs in other cars . . . But no, in an S550 one has to be a blind contortionist to replace it.
Konamoth
Konamoth
Atlanta, GA
Nick
Very true. I can't say I've started pulling plugs often for things just yet. But there's even grippy ridges on the OTHER side of the plug like you're meant to press from there!
Forreal. I swear the engineers made it a mission to put things in the most inconvenient spaces available.
shogun32
Northern VA
2019 GT+PP, SS+1LE, 2020 F150
but it looked so pretty in the CAD preview, spinning it around on it's 3 axis. Ford engineers have never lifted a tool, skinned their knuckles, or soiled their shirts except with nacho cheese. But they are wizards at that AutoCAD thing they picked up at Uni.
Mike Pfeifer
New Lenox, IL
2019 Ruby Red Mustang GT A10
Must have learned from BMW…
Weyland-Yutani
ATL USA
'18 Mustang GT, '17 Volvo V60 Platinum, '04 E-150
Looks like a Delphi connector, but I'm sure Delphi engineers are also turds. We're all turds.
I did get some dirt on me last Tuesday though. I mean, technically the dirt fell on me, but I still got dirty in the one spot.
Cobrajet70
clermont
Jamie
21 Mach 1 Hp
I pull connectors with just two fingerers all day long with out even thinking about it. One "trick" I tell new guys is to Push in the connector before releasing it. They like to jam on the lock tab and pushing thing them in clears the lock tab to get it to release. Very common to need to do this on coil connectors if you Don't want to break them.
West palm beach, FL
Tae
2016 Ford Mustang GT Premium
I know I’m late to this, but I was out tryna put a Pedalmax on my 2016 GT today and couldn’t figure out how to remove that tab and broke the top part of that red tab off, anybody know where or a part number I can get a new one to replace or how I can fix it maybe lol
119 - HP Tuners - 1
