Anyone run a Sai Li fuel return on their 18+?
gimmie11s
SoCal
Murica!
Lol I was thinking about Fore 1E. Aren’t you going TT? I wanna see if I can safely do Sai Li with 1050x’s for my Procharger set up.
Yeah. Have everything sitting on shelves right now. Only thing I’m waiting on is the Sai Li system.
Hope it delivers this week then I’ll start tearing into it.
You ought to be good to at least 850 with the blower and e85 on the dual fuel 2018.
10r80
Dallas
2018 GT
Did you get a Black Friday/Cyber Monday deal on it? I guess I’ll stay tuned and see how it works for you. What are your goals with it?
gimmie11s
SoCal
Murica!
Yeah lethal had them for $950.
Goal is 850-900.
Det_Riot
Royal Oak, MI
Bryan
1994 Mustang GT, 2018 Mustang GT
We just ordered this for my fiance's 18. Setup will be whipple 3.0, e85, etc, etc, etc. Starting with the 3.75 pulley and seeing how small we can go on this fuel set up.
helloWorld
Lincoln, NE
2004 Nissan Maxima SE
At what point do I need an aftermarket fuel rail? I purchased the 1050X injectors and the Sai Li kit for my '18 that I plan on going turbo with. I was just going to stock around the 750 whp mark for a while.
beefcake
Bethel
2018 Ford Mustang
we recommend the fore systems with rails on the 18's. the 18 up rails do not flow as good as the stock rails.
if you have a whipple that has rails, then a system without rails would be ok.
we offer both ways
Logan@Lethal
Tampa, FL
www.lethalperformance.com
Logan
2020 GT 3.0L Whipple
We've had quite a few customers use it on their 18's and Sai did the testing on a 18 with a vortech. It plain works. It's the cheapest return fuel system for a stock block. For Whipple guys, we also developed a setup that we used our 18 as a test dummy. It'll support 1400hp+ if you go with the triple setup.
gimmie11s
SoCal
Murica!
How much power does the Sai LI kit support on a twin turbo 18 with stock rails, e85?
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
7 horsepower. ;-)
Do your research, get what you can afford, have fun.
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Huh?
Thanks dad. Appreciate the words of wisdom.
Sure seems like you're ignoring all the "dad wisdom" being providing to you. Sure hope you can hit those 11s you're asking for, gimmie11s.
fiveoboy01
Madison, WI
2017 LB GT 400A
It was a pretty simple question. Snarky dickheaded answer wasn't required.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
I don't think stock rails will be an issue at 850ish. With DI helping by 20% it should be fine. There are a couple ways to do it with one regulator. I would set it at 58 psi without a boost reference and watch fuel as you up the boost. You can install a vacuum check valve and boost reference to manifold for boost only just make sure DI is always 58.
