Thank, you. Can the cover be removed with everything else in place ? Or do i need to remove anything? I just need to reseal the cover since it is leaking.Here, This may help.
It is the: SHELBY GT350 REAR DIFFERENTIAL COOLER INSTALLATION INSTRUCTIONS.
It's for the GT350, but everything should be the same on the cover itself.
On page 13 & 14 it shows replacing the rear cover, with torque specs, etc.
You may need an E-Torx Socket, (E-18) for the inverted Torx bolts.
FORD says to drop the housing down.Thank, you. Can the cover be removed with everything else in place ? Or do i need to remove anything? I just need to reseal the cover since it is leaking.
