tcman54
Stanghead
- Apr 11, 2016
- Palm Coast, FL
- Terry
- 2016 Ecoboost
- Vehicle Showcase
- 1
Trying to install mine and it's impossible. There is no way in the world to reach down underneath the engine cover and loosen the quick connect hose on the manifold side without taking off the engine cover, in order to do that I need to take off my strut brace, in order to do that you have to remove the positive batter cable, this is nuts.
Has anyone been able to do this, does the engine cover easily remove or does one have to drill out what appears to be plastic connector screws in the top in additional to removing the nromal bolts?
And then to get to the quick connect hose on the engine block side one has to either lift or jack the car, when jacking the car is there one jack point in front or will I have to jack the one side put it on stands and then the other?
Also when one disconnects the hoses is fluid going to come out?
Thanks
Terry :frusty:
Thanks
Terry :frusty:
