So I really struggled with this exact issue. I ended up going for a set of 3 way components (there are a few options out there) as it was the cheapest way to get a higher quality set of 3.5" mid woofers.Thinking about replacing the 3.5 door speakers. Want to match factory impedance (2 ohm). Can't find any that aren't coax. Anyone find a non-coax 2 ohm 3.5?
2ohm kits are available (hard to find though), but if you're replacing all the speakers in the cabin, it doesn't need to be 2ohm. To be honest, you could even replace the doors speakers with the 4ohm three way kit, remove the center speaker (please do, you won't regret it!), and leave the 2ohm rears (unless you want to replace them). The volume difference between the 4ohm and the 2ohm is negligible, but could be offset by simply shifting the balance further to the rear of the car.2 ohm?
