Anyone done a custom sub in the spare tire well?
Keith_PDX
Portland, Oregon
2017 GT/PP
Been using Google without success. Anyone seen a custom box in the spare tire well? Links?
Thanks!
Chef jpd
Brooklyn, NY
vnzbd
So FL
2016 V6
Some one on here with a GT350 put a JL micro 6.5 in there. I tried an 8" version and it was pretty decent. I now have a JL 10WT3 in a homemade box. It is not wildly custom as it is just a box. It is clean and stealth with good depth and output. No pics as of yet.
Keith_PDX
Portland, Oregon
2017 GT/PP
What are the dimensions of the box you threw down there? Did you perforate the carpeted truck bottom that lifts up for access?
vnzbd
So FL
2016 V6
JL sealed spec called for 16 x 13.875 x 6.5 OD or 1,143 cubic". I went at 23 x 12 x 4.5 OD(before triple baffle so actually 6" thick) or 1,173 cubic". That allowed for some bracing. 3/4 MDF was used. Due to the parameters of the woofer I used, minimum depth and thick face and excursion I did a triple front baffle. The sub is mounted to the first and the second and third provide depth to protect the speaker.
I did not perf the carpeted area as it is not needed for sound. My amp is down there as well so I am monitoring temps on it for now. It is running cool. I did however remove my rear speakers as I do not use those. I doubt they were much if any of a sound restriction but at one point with a different sub that had limited output I was grasping for straws.
S550HPP
PDC
2022 HPP Vert
No benefit. The OE enclosure treated with sound deadening inside and out along with. $300+ sub and 400+W @4 ohm amp in the well. Can also put some spacers in-between the seat back and bottom to open the airflow from trunk to cabin.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
While I didn’t put my subs in the well I have my amps there in a custom setup. You have enough airspace to run at least a 10 or shallow mount 12.
Here’s my setup.
And the finished product:
Bassackwards
Nashville
2022 GT/CS convertible
I use my trunk to haul tools and such and was concerned about damage. I put mine in the factory location
69mach1-395
central nm, usa
2016 RR GT/CS
Adam the Lighting Guy
West Palm Beach, FL
Adam
2021 GT Convertable , California Special & 2020 Ecoboost Premium Coupe
I'd love to use the spare tire well to house amps, but im paranoid of not having a spare. I guess everyone either carries plug kits and compressors or had a great roadside plan. Or maybe I should just say Eff it and let it fly because it's a weekend car. I really dig all the creativity on display of what you folks have done.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Well you can always throw a spare in the truck if you go on a longer trip and carry a tire plug kit and compressor locally. I have a pack of CO2 cartridges and tire plug kit for local drives.
m3incorp
Georgia/Colorado
James
Interesting touch adding the fans for cooling.
Not exactly. But this is what i did in my spare tire well and for a subwoofer
m3incorp
Georgia/Colorado
James
I always keep a plug kit and battery-powered air compressor in the car, as well as USAA.
