any leads on White GT500 non track pack
jsg1518
New Hyde Park, NY
Joe
none at the present
I tried to change the distance from 100 to 500. It won’t let me change it. Is there a trick.
oregongt350
Oregon
Michael
2022 GT500 HE, 1967GT Fastback S code,
Same on my end no 500 mile drop down. That’s why I end up using Car Guru, but as the gentleman stated not all dealers use Gurus
onelfastlride
GT500
Edit the URL up in the web site address info. If you look, you will see your zip code & 100. Click on the web address, change the 100 to 500, then hit enter. The choice for 500 mi radius is not in the drop down, it will appear there after you've changed the URL. You could probably change that 100 to whatever number you want within reason.
SVTFreak
#275
Prairieville, LA
2015 Wimbledon white LE #275 A6
as one fast ride said you haveedit the address in the url bar.
TxGT350-52
SE Texas
2018 GT350 Lead Foot, 2021 Diesel Tremor CG
You can change the value to whatever you want, but the algorithm they use on the backend can only handle 100 dealerships. As others have discovered, if you make the mile range large enough to include more than 100 dealerships, it will lockup and not return anything.
In some zip codes you can only use 400 miles, while others can handle 500 miles based on the number of dealers in the range. I can find all the cars in Texas by strategically choosing three zip codes in the state and making sure some of the listed dealers in each group are overlapping.
