Zrussian13
Hey guys! Finished my hellion street sleeper kit 2 weeks ago and completed remote tuning shortly after. Car runs great! Feels totally stock out of boost, drivability is spot on but once you get on it the car screams! Base turbos with jms bap and dw95s running on 5lb springs. Hellion says they put 7lbs to the engine. Tuner agreed I'm sitting at 6-7lbs but my boost gauge is on backorder so I cant monitor yet. Got a couple questions....
First off exhaust- I purchased the borla S-type with the kit. It showed up early so I slapped it on and it was way too loud for me! I went ahead and ordered the 60661 borla resonator and it did the job quieting it down but the resonator is 2.5" and it necks down to 2 1/4" at the connects. When I put the hellion kit on I cut the connects off so it only bottle necks down to 2.5". I'd like to change out the resonator so it's 3" all the way through but I need ideas. I'm trying to keep it quiet as possible so some form of 3" resonator would be ideal. I looked at vibrants and don't have the room. I've found some bullet type resonators that will fit but not sure how much they will help. Found a magnaflow xpipe muffler that matches the borla resonator size that looked promising but then I found sites that say it's not a true x pipe and goes through a single 3" y pipe. Any input would be appreciated.
Secondly, I drive a lot. I put 1,000 miles on the car since I finished everything a week and a half ago. I have a work truck I could drive but I really enjoy opening the gt up on a daily basis so I only drive the truck when necessary. I probably get into boost good about 5-6 times a day at least. Running on 91 out here plus 1/3 bottle of boostane per tank. Am I at a relatively safe level of boost? Or should I be cautious? I know you have to pay to play and I'll build the motor when the time comes but I'd like to ride the stock block out as long as possible.
Almost forgot... 2019 gt pp1, kit went on at 48.6k miles. Sitting right under 49.6k when I got home from work today.
