Open Loop
- Nov 16, 2019
- Pittsburgh
- Peter
- 2016 Mustang Premium PP, 2013 Scion FR-S
I apologize if this has been asked before, but here it goes:
I am running Steeda progressive springs, and I am evaluating whether to go with 19x11 ET50 wheels for track use. Let's assume for the moment that they will be shod with 305/35 tires.
On the front, I intend to run 25mm spacers. The spacers I have currently are of the type that you bolt to the original studs, which then have their own studs of a high-quality material. For track use, does this type of spacer give anyone pause?
WIth respect to the rear of the car, I am planning to run about -1.7 degrees of camber. Will this work without rubbing?
WIth respect to the front including 25mm spacers, what sort of negative camber should I expect to be able to run? Will there be room to adjust between say -2.5 and -1.5 degrees?
Thanks in advance.
Thanks in advance.
