He said cheaper, not necessarily better. That's why the MSRP dropped so much in 2018 and 19.2011 to 2017 had cast iron liners and no scuffing issues, so in you opinion PTWA is better got it.
Theoretically, yes it is far better material. It is specifically engineered to be much harder, and has an identical expansion and contraction rate to aluminum. Plus, the material having molecular bond to the aluminum makes it a far superior way to go.2011 to 2017 had cast iron liners and no scuffing issues, so in you opinion PTWA is better got it.
Stick your head in the engine bay just above the A/C Compressor. Is it louder? If you focus, can you feel it in the shifter? If so, that's the old classic issue that was never fixed as they never changed the position of the A/C Compressor relative to the crank.. Old fix was to add a tensioner to the compressor belt line.
That TSB is for 2011-2012 Mustangs. I'd hope by now they would know how to design belt drive systems based on lessons learned from prior TSBs.Stick your head in the engine bay just above the A/C Compressor. Is it louder? If you focus, can you feel it in the shifter? If so, that's the old classic issue that was never fixed as they never changed the position of the A/C Compressor relative to the crank.. Old fix was to add a tensioner to the compressor belt line.
Not a durability issue, just noise.
https://latemodel.cachefly.net/downloads/tsb05-14/tsb12-08-14.pdf
Nope. Not sure why. The trucks all get a tensioner which eliminates the noise, but they use a stretchy belt on the A/C Compressors for Mustang. I don't know if it's cost, or weight, or what. But if you go look at your FEAD right now, it's a stretchy belt.That TSB is for 2011-2012 Mustangs. I'd hope by now they would know how to design belt drive systems based on lessons learned from prior TSBs.
Nicasil is great - until it flakes. I've seen nic failure in a few snowmobile cylinders, it gets ugly in a hurry.I worked at a company that electroplated nickel silicon carbide (nicasil) onto engine bores. We repaired and or plated all kind of aluminum blocks from as small as 50cc single cylinder motorcycle engines to large bore V8 engines. Plated bores be it NiSiC or PTWA, are an advancement over cast iron liners. Better wear characteristics, better heat transfer, More consistent cylinder geometry, tighter piston to cylinder wall clearance, less friction, less weight, and less machining costs are some of the obvious benefits.
Yes, I saw plenty of cylinders that flaked but...95%, if not more, were two stroke cylinders. Lots of ports and edges to cause issues. Add this to just a wisp of oil for lubrication, lean jetting and big power for their displacement and you can get flaking. However, if plated properly with good lubrication, proper piston/cylinder wall clearance and reasonable jetting it is a BIG advancement over a cast iron liner. On 4 stroke engines, I rarely ever saw any issues.Nicasil is great - until it flakes. I've seen nic failure in a few snowmobile cylinders, it gets ugly in a hurry.
Correct, usually 2-strokes are the culprits for all those reasons.Yes, I saw plenty of cylinders that flaked but...95%, if not more, were two stroke cylinders. Lots of ports and edges to cause issues. Add this to just a wisp of oil for lubrication, lean jetting and big power for their displacement and you can get flaking. However, if plated properly with good lubrication, proper piston/cylinder wall clearance and reasonable jetting it is a BIG advancement over a cast iron liner. On 4 stroke engines, I rarely ever saw any issues.
