It's an inch more of a diameter - it will likely fit (may rub if you bottom out the suspension which is rather unlikely for most people) but will significantly affect your speedometer accuracy and will look somewhat weird.So i have the black accent package with the 19x9 rims on my car. Tire size is a 255/40/19
Wondering if 255/45/19 will still work as i found a set of tires i really don't want to pass up on.
Any help would be great.
Mostly. I can't tell for sure if that would rub or not - take a look at the front strut and see if with compressed suspension half an inch makes a difference.won't it just have that meaty look? I don't really care about speedo
My winters are larger than stock and my summers smaller, by almost the same amount. I figure it evens out :lol::lol:Keep in mind unless you change the programming with Forscan or a Whipple Flare Tool not only with the speedometer be inaccurate by 1-3mph but your odometer will be incorrect also.
That works :lol:My winters are larger than stock and my summers smaller, by almost the same amount. I figure it evens out :lol::lol:
Yep. I put a 225/55R18 Blizzak WS80 on the stock 18s. They work great.For best results you would want a taller narrow tire for the snow.
