Al's GT Procharger/Airlift Build
uscavman
Killeen, TX
Al
2016 Mustang GT Premium
Clutch install
Clutch went in fairly easy minus installing the flywheel alignment pins wrong and having to remove and reinstall it.
uscavman
Killeen, TX
Al
Shifter support and DS loop
Shifter support install
uscavman
Killeen, TX
Al
Front bag install
Front bag install. After getting the wheels on, front wheels would not spin. As shown below material had to be removed from the lock collar along with the addition of a 1/4" spacer to allow the MRR M350 wheels to clear. The spacer limits the drop height so I'm going to look at putting on Gt350 fenders on. I have 3mm and 5mm spacers on the way and will see if that helps.
uscavman
Killeen, TX
Al
Rear suspension/differential/axles
Almost everything in the rear back in. Differential came out and replaced because of improper back lash. 3:73 gears were removed for 3:31. I ended up having to buy a loaded 3:55 differential without Torsen to get this thing moving. Gonna send the Torsen 3:31 differential out to get properly gaped. My buddy has been doing 8.8 gear swaps for decades but the new super 8.8 IRS takes special tools to install and gap properly. The howl from the rear was deafening. 3:55 is in and sounds great. The increased noise from the solid bushing kits are acceptable.
uscavman
Killeen, TX
Al
D1SC install
D1SC install. Destroyed the first belt by not setting the tension properly. Second belt installed worked great after adjusting the tension. Working with Lund finishing the tune.
cgreen5150
cgreen5150
Loomis, CA
2015 GT, Premium, PP, Recaros
That's some serious work you busted out. Looking great!
Rebellion
Houston
2016 Competition Orange GT
Is that the new Barton Hybrid?
dink32788
San Diego
Kevin
2016 Magnetic PP Mustang GT
Incredible build so far! That's where I'd like to be eventually... But going to take longer than buying everything at once lol. Props my man!
uscavman
Killeen, TX
Al
Thank you!! Currently It's at the 2.5-5.5 WOT stage of the Lund tune process. I ran out of time and having my friend help me out.
Still needs:
Airlift height senors installed.
Four wheel alignment.
Some reason I'm getting the low brake fluid light coming on/off intermittently. Gotta find the loose wire or maybe it's the level sensor.
Hopeing I can get in on a boat to Germany in a few weeks.
Stage_3
MA
2019 Roush Stage 3
Awesome stuff man! Great thread here.
Stay safe and thank you for your service. :usa:
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
Woah. Bad ass build.
Then I looked at your location and noticed you're local to me. Sweet.
