homegrown
- Apr 29, 2016
- Cut-n-Shoot, Texas
- Stacy
- 2016 GT Premium PP Manual CO
Got my UPS tracking info!
Thanks!![MENTION=24574]Badluck[/MENTION]
Gloss black 6GR's look killer
i'm not sure what could possibly be unsafe... are you getting enough suspension travel to tuck your tire with your original wheels?Yeah the car is lowered on Steeda Progressives
is the car unsafe to drive at this point? All the lugs are torqued to 115
Yeah my original wheels are the pp wheels and they tuck about an inch.i'm not sure what could possibly be unsafe... are you getting enough suspension travel to tuck your tire with your original wheels?
I am not really worried about that, there is plenty of room between the tire and the fender. I will update this thread after I take it to the shopthe only thing unsafe i can think of is you get enough suspension travel over something to get tire to fender contact eg. sideways at the entrance of a steep driveway.
Could be subframe off by a bunch.Yeah about to get home and I'll post some up
I am positive they are the same offset so that can't be it. As for the mounting I did it this afternoon and I took both wheels off a couple times to see if I had mounted them incorrectly. All four are flat against the hub, that's one of the reasons I am so confused. Hard to tell what would be causing the problem since it should be symmetricalCould be subframe off by a bunch.
Almost Looks like different offset wheels or wheel got hung up on hub centering lip. You shouldbe able to find the offset marked inside the wheel.
The wheel sticking out might not be mounted to the hub face.
Before driving this anywhere, consider jacking up and removing that wheel.
Do you have a jack stand or some timber or blocks or something to backup the jack on?
You can use a piece of putty or unchewed gum etc to make sure it all gets squeezed out from between hub n wheel when remounted. If not, could be couple reasons all correctable.
Try swiping the rears, if the poke moves to the other side its the wheel.I am positive they are the same offset so that can't be it. As for the mounting I did it this afternoon and I took both wheels off a couple times to see if I had mounted them incorrectly. All four are flat against the hub, that's one of the reasons I am so confused. Hard to tell what would be causing the problem since it should be symmetrical
Thanks! I used G2 Caliper paint, pretty impressed with the product.[MENTION=24574]Badluck[/MENTION] very nice, I really wanted to do yellow calipers but chickened out. You ever see another magnetic on project6GRs it's likely your fellow arkie here:cheers:
I saw your car on here a few weeks ago. Friends and I go Dove hunting around Black Oak and stay in Jonesboro at nights. I was looking for your car when I was there! Lol[MENTION=24574]Badluck[/MENTION] very nice, I really wanted to do yellow calipers but chickened out. You ever see another magnetic on project6GRs it's likely your fellow arkie here:cheers:
