- Aug 9, 2014
- Fort Bragg, NC
- Jason
- 15 PP
We just finished installing our Airlift system on our Whippled 2015. (those going to Mustang Week make sure to stop by our tent)
PM us for forum specials during the holidays!!
Coil-over suspension can’t compare with the versatility of air. With infinitely adjustable ride height, and a lift capability to stock height, no longer do you need to worry about driveway entrances or speed bumps in order to enjoy a lowered car. Forget about the punishing ride that goes with many conventional suspension choices.
And the handling? Air Lift air suspension products are tuned on the racetrack. Countless laps and numerous competitions helped our engineers hone the handling to razor-sharp precision, not unlike premium coil-overs. Guys that race Mustangs have been in the car, and are amazed by the cornering capability and flat cornering nature of the suspension. While you may never intend to track your Mustang, it’s good to know that your car is capable of handling whatever the road throws down.
So what does it take to have such a versatile suspension? It all starts with having a strong foundation. In this case, the struts: Air Lift uses 30-way adjustable, monotube struts—with a serious range of damping adjustment—that have been specially tuned to match the air springs. Monotube construction is the preferred choice in racing, and it’s the preferred choice for us; its sensitivity to small inputs, as well as the great ability to shed heat when pushed to the limit, make it top-notch in our book. The 30 clicks of adjustment aren’t just for fun, but they allow you, the user, to dial in your preferred handling feel or desired ride quality. The range goes from super-stiff to very soft, adjusting rebound and compression together, but with proportionally more rebound. The struts weigh considerably less than the coil spring parts you remove, reducing unsprung weight—a benefit to both ride and handling.
What sets these struts way apart from the coil crowd is the addition of our adjustable, progressive rate air springs. These high-rate springs create a stable platform for aggressive track-driving while providing a level of comfort not typically found with lowered suspensions. By using this progressive style of air springs and maximizing available suspension travel, you’ll be able to ride low without the punishing ride. And since they allow ride height to be adjusted with a button, no longer do you suffer the curses of static suspension lowness! No more issues with speed bumps or steeply angled drives. Raise it up as high as stock to ride off-road without damaging the under body, and just think how easy it will be to load it on the trailer or get your jack underneath.
As the leader in air suspension products for over 60 years, Air Lift is committed to delivering quality parts that last. To ensure longevity for the customer, the key suspension components have been tested on a durability rig for over one million cycles, which equates to 100,000 miles. With a one-year, unlimited-mileage warranty, you can purchase this kit with peace of mind. Installation is simple; only basic hand tools are required to complete the job. EVERYTHING is included with the combo kits: front air struts, rear air springs, and tuned shocks, as well as an in-cockpit control system. There are no modifications required in front, and only four small holes to drill in the rear spring pocket area. If you can wire a stereo and swap suspension parts, you can install this system yourself!
What’s the bottom line? Great looks, awesome performance, exceptional versatility, proven durability, and easy installation…only from AIR LIFT PERFORMANCE!
Kit Specs:
Kit Specs:
- Front suspension travel = 130mm/5.12".
- Rear suspension travel = 106mm/4.17"
- Front spring pressure for ride height = 42psi
- Rear pressure for ride height = 50psi
- Possible camber adjustment:up to 3 degrees negative camber
- Front kit shipping weight and size: 40 lbs. 23-1/2"x 14 7/8" x 8"
- Rear kit shipping weight and size: 16 lbs. 23" x 9" x 5-1/2"
- Modifications Req. Front: NONE
- Modifications Req. Rear: Drill 2 holes near rear spring location. Covered by interior trim
- Auto Pilot Digital Controller
- Controller Mounting Bracket
- Digital Controller ECU
- Pezio Transducers
- Anodized Manifolds
- 1/4" Airline
- Our Air Line Cutter
- VIAIR 380C 200 psi Compressor
- 5 Gallon 8 Port Tank
- Inflation Valve and Drain Cock
- Wire Harness
- Thread Sealant
- Compressor Relay
- Nickel Plated Fittings
- All Necessary Mounting Hardware
