ahl395's Magnetic GT Build Log - Procharger P1X + 8kW sound system
Discussion in 'Members Mustang Journals / Projects' started by ahl395, Apr 23, 2017.
  1. 15dib
    15dib Well-Known Member
    Vehicle(s):
    2015 Mustang
    Jun 17, 2016
    texas
    401
    Capacitors are a joke and a waste of money. For the amount of power he's going to push he needs those ground wires coming directly from the battery. He can install a dry cell battery in the trunk and run a single ground cable to it and then ground the battery back to the frame of the car.
  2. Cobo_pro
    Cobo_pro Well-Known Member
    Vehicle(s):
    2017 mustang gt
    Jun 17, 2017
    401
    43
    Rating:
    100%
    1   0   0
    Optima is a dry cell home slice. And do your homework before you try to school someone who used to do this for a living
  3. 15dib
    Vehicle(s):
    2015 Mustang
    Jun 17, 2016
    texas
    401
    I didn't say optima wasn't a dry cell battery, but you should really look into tests that have been made about capacitors. They're a thing of the past and maybe that's why you think they help in a 8k system.
  4. OP
    ahl395
    ahl395 Well-Known Member
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    Thanks man. I had 0 gauge ran through my old car but like you said 1 is easy to run through the interior lol.
    I thought about it but didn't want to cut any corners. The frame of a car cant conduct electricity as good as a copper wire. Especially most cars today that dont have an actual "frame" and its several pieces of metal welded together. Ground is even more important than power wire really. Electricity flows from neg to pos.
    As mentioned above, the metal on the body cant conduct electricity as good as a copper wire. For most systems grounding to the body/"frame" works fine. Evne in my old system which was about 3kW RMS I did this. However at 8kW using the body as a ground really just isnt good enough. The ground really is more important than the positive.
    I am going to be running an XS Power D3100 in the rear which is a car audio AGM battery. Optimas are a bit overrated in my opinion and personally I think there are better options out there. I've been a fan of XS for awhile.
    Agreed that at this power level I need the dedicated grounds.
    On capacitors... Everybody has a different opinion on them. Personally I think that many of them are cheap garbage and don't work. HOWEVER, I have seen evidence that some of them do work. I'll link a good video below.
    That being said, at this power level I would need a ton of caps to really do anything, and I think it would only be a marginal improvement. Which is why I went with batteries. I have read alot of good things about XS's supercap banks, and Rockford's Hybrid Capacitor... But in the end it's still a bandaid for more real power output. This is why I went with a 370A alternator (and the batteries).
    [ame]
    This video is done by an engineer that used to work for Rockford Fosgate. Being a big fan of them I tend to trust his testing.
  5. 15dib
    Vehicle(s):
    2015 Mustang
    Jun 17, 2016
    texas
    401
    Xs batteries are great man. Are you going to replace your main battery with one as well? Agree on the copper/chassis ground with you, that's why I commented on the extra battery in the trunk. Seems like you know what you're doing bro. Hopefully everything goes as planned.
  6. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    Thanks man I appreciate it.
    I'm replacing the one up front with an XS D4700. So between that, the D3100 in the rear, and the 370A alternator... I'm hoping to have sufficient power. And no light dimming :headbonk:
  7. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    Got my car back with the MAK Deletes and resonators!
    Comparing it to videos I've watched I definitely think the resonators helped cut down some rasp and volume. The shop agreed that it was tamer with the resonators. Video below of cold startup, the camera definitely picks up more rasp than you hear in person. Driving with it, its extremely loud but it sounds great. Very rough and choppy sounding now, reminds me of a motorcycle sometimes.
    More pics and video to come soon.
    My girlfriend was rushing me to leave so I had to cut this video short lol. Will get a rev and takeoff video soon, as well as pics underneath the car.
    [ame]https://vimeo.com/232476203[/ame]
    Martinnfb likes this.
  8. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    #68 ahl395, Sep 8, 2017
    Made alot of progress on my subwoofer box today. Got the box itself all together except the top piece, subwoofer and terminal cutouts. Still undecided on whether to stain it, carpet, or paint it. Leaning towards staining it.
    This thing is giant and is just barely going to fit.
    Also took a warm start video of my exhaust.
    [ame]https://vimeo.com/233079885[/ame]
    And here is a picture of one of the cats that came out of the car. Ignore the dark spot that is just from the camera lining up with the honeycomb of the cat, it's not a burnt mark like I originally thought. You can see some imperfections over on the left side, I wonder if this has anything to do with the FI.
    [​IMG]
  9. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    #69 ahl395, Sep 10, 2017
    My car must have 1000ft of wire in it at this point. Lol
    Ran the following wires today...
    4Ch RCAs
    Speaker wires for front tweeter, mids, woofers
    Helix DSP Bass Knob (ran through center console)
    Power wire to meth injection system controller
    Power wire to meth injection pump
    Remote wire
    Relay wire
    Meth tank low level sensor wire
    Meth system stainless braided line
    None of it connected yet, but just running them took a good part of the day :lol:
    RCAs are KnuKonceptz Triple Shielded. Speaker wires for the woofers are 16AWG, tweeters and mids are the large blue cable which is 18AWG speed wire. Wires may seem small but theyre matched correctly for the amount of current going through them to meet the 300 circular mils per amp standard. Believe it or not all the panels went back on and look good, cant even tell theres 100 wires ran through them lol.
    IMG_20170909_160826.jpgIMG_20170909_144222.jpgIMG_20170909_173842.jpgIMG_20170909_163030.jpgIMG_20170909_163105.jpg
    Also took a drive by video at light throttle. The sound from the BOV can be heard hundreds of feet away and the exhaust is crazy even at mid/light throttle. The best part of the video was the guy coming out to the street complaining :lol::lol:
    [ame]https://vimeo.com/233159024[/ame]
  10. cgreen5150
    cgreen5150 cgreen5150
    First Name:
    Vehicle(s):
    2015 GT, Premium, PP, Recaros
    Jul 20, 2016
    Loomis, CA
    587
    223
    0   0   0
    Too funny! It looks like you're just cruising and not getting crazy. Did you do some aggressive drive-by earlier or is he just the grumpy "get off my lawn" old man?
  11. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    Before that we were doing some mid throttle drive bys. Still slow and under the speed limit but the car is so loud it sounds like your flooring it :lol: I use that road for testing and the grouchy old man has come over and given me crap before lol. Sounds like I'm racing even though I'm under 35.
  12. Cobo_pro
    Vehicle(s):
    2017 mustang gt
    Jun 17, 2017
    401
    43
    Rating:
    100%
    1   0   0
    What part of NJ you in Ahl, I'll be in Bergen county in 2 weeks
  13. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    #73 ahl395, Sep 21, 2017
    Got under the car today to check for false knock. Took a look at the MAK Cat deletes and resonators while I was under there. And tightened up some of the sound system wire which drooped after driving with it for awhile.
    Amazing how much room is in there without the cats in place. I was also surprised how cool the pipes were even after just driving. Those cats really retained heat before.
    As far as false knock results I found the BOV had some marks from hitting the grille opening I made, so I made it slightly bigger (forgot to take a pic of that). My resonators are very close and almost touching so I thought they may be hitting eachother, but directly after them is the H pipe so they are completely solid. I couldn;t get them to rattle or touch eachother. So idk :shrug: Pics below.
    IMG_20170921_072603.jpgIMG_20170921_072714.jpgIMG_20170921_072808.jpgIMG_20170921_091110.jpgIMG_20170921_091112.jpgIMG_20170921_072749.jpg
    Oh awesome. I'm in Monmouth/Hudson county. Shoot me a PM would be cool to meet up!
    Martinnfb and Mootang like this.
  14. Cobo_pro
    Vehicle(s):
    2017 mustang gt
    Jun 17, 2017
    401
    43
    Rating:
    100%
    1   0   0
    For sure bro, will do
  15. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,490
    987
    Rating:
    100%
    1   0   0
    #75 ahl395, Sep 22, 2017
    Finished up building my subwoofer box today! Still has to be carpeted, sealed, and wired up. But at least the structure is done. Took a few shots of the subwoofers going in also and the massive 4" voice coils. Pics below.
    Made supports on the back of the box to keep it 4" off the back of the trunk for room for my methanol tank and/or fill pipe. Got a quote for the methanol tank I posted designs of in the last page and the quote is way too high. So I will be trying another design making the tank wide as the trunk and 4" thick behind the box which will be a simpler design and hopefully cheaper.
    IMG_20170922_113809.jpgIMG_20170922_113857.jpgIMG_20170922_130247.jpgIMG_20170922_130255.jpgIMG_20170922_153936.jpgIMG_20170922_154004.jpgSnapchat-904319637.jpg
Loading...
Share This Page
