ahl395's Magnetic GT Build Log - Procharger P1X + 4500W sound system
Discussion in 'Members Mustang Journals / Projects' started by ahl395, Apr 23, 2017.
  1. OP
    ahl395
    ahl395 Well-Known Member
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    AND SHE'S BACK!!!
    Felt so good to drive it again. Looked at the calendar and it has been exactly 3 days short of one year since it broke and I drove it last.
    I wasted no time, and after I got it home I installed my meth tank.
    Mounting board
    Tank Installed
    Access hole to pump
  2. Chris Barnes
    Chris Barnes Well-Known Member
    Vehicle(s):
    2018 PP GT
    May 12, 2018
    Arizona
    355
    175
    0   0   0
    Can't wait to see the progress. I'm totally Jones'ing to see how your meth system works. May copy you once again when you sort it all out!
    ahl395 likes this.
  3. turnswrench
    turnswrench turnswrench
    First Name:
    Bowman
    Vehicle(s):
    18 Royal Crimson Mustang GT A10
    Apr 2, 2018
    MN
    1,225
    638
    Rating:
    100%
    5   0   0
    Heck yes, Congrats!!
    ahl395 likes this.
  4. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    Thank you guys! I appreciate everyone following the build.
    Meth system to be installed tomorrow. Dyno tuning should be sometime next week! So far I've done one WOT pull for a datalog. Felt good and strong. Made 10psi at ~6700 with the 5psi spring in it and around 18* timing. Once I get the approval from Lund I can see if it can take any more and what itll make at 8k.
    The wastegate is SCREAMING bleeding off all that boost at high rpm lol. I'd have liked the boost to be a little lower on spring pressure but it's not bad. An 8k pull will tell for sure but I think it will work ok for the failsafe.
    Check06 and jabrax like this.
  5. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    Direct port is installed and leak tested!
    Installed some heat wrap around the coolant lines since I had to relocate them to the sides they're no longer ran over the insulating foam. Didn't want the hot coolant hoses against the fuel line/fuel rail or melting the electrical under them. I don't particularly like the way the heat wrap looks though. I may put some black split loom over them or something.
    Have to get some pics in better lighting but I love the way it looks, minus the tin foil wrapped hoses lol.
    Loving this thing already. When test spraying on low duty cycle the entire manifold was COLD to the touch. It was awesome being able to feel the meth in action.
    Purging the main feed line
    Final install
    9th nozzle in the pipe for IAT reduction
    bluebeastsrt, JPSTANG and turnswrench like this.
  6. JPSTANG
    JPSTANG Well-Known Member
    First Name:
    Joe
    Vehicle(s):
    2017 Mustang GT
    Oct 15, 2018
    MN
    173
    122
    Garage Profiles:
    Rating:
    100%
    1   0   0
    Dude where you at, cause I'm gonna buy you a new cresent wrench. Lol... very interesting set up. Following!
    turnswrench likes this.
  7. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    Snapped a pic of my cockpit. Cortex controller and AEM failsafe in the gauge pod. Injection activity and low tank level LEDs on the left. And the screen for my radar detector mounted on the vent. Love the way it all looks.
    Whats the matter with my rusty old one? Hahaha. Thanks man.
    JPSTANG, turnswrench and bluebeastsrt like this.
  8. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    Got some better engine bay shots. Loving the unique look.
  9. Jay-rod427
    Jay-rod427 Well-Known Member
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,336
    913
    Rating:
    100%
    4   0   0
    I just hear Willie Nelson playing. "on the road again"!
    ahl395, bluebeastsrt and turnswrench like this.
  10. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    First oil change! Got the break in oil out.
    Also the search for false knock begins again....
    GuardEcoBeast likes this.
  11. JPSTANG
    First Name:
    Joe
    Vehicle(s):
    2017 Mustang GT
    Oct 15, 2018
    MN
    173
    122
    Garage Profiles:
    Rating:
    100%
    1   0   0
    Let me know where you find it, cause I'm still looking for mine. Lol
  12. RalphK
    RalphK Well-Known Member
    First Name:
    Ralph
    Vehicle(s):
    2020 GT PP2
    Apr 10, 2020
    Central Ca
    65
    Don't you need 2 more quarts?
  13. 80FoxCoupe
    80FoxCoupe Well-Known Member
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,567
    929
    Rating:
    100%
    5   0   0
    Only 8 needed for 15-17
  14. OP
    ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,753
    1,137
    Rating:
    100%
    1   0   0
    Couldn't find shit lol, even beating the exhaust with a mallet. I secured some stuff in the engine bay better. Nothing I really think could cause it but you never know.
    Lund is going to "change the logic of the knock sensors" so it's not as big of an issue anymore. I resisted doing that for this long but I've had it with false knock lol
    Yeah only 8 for 15-17. However mine usually takes 8.5 for whatever reason.
    JPSTANG likes this.
  15. Jay-rod427
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,336
    913
    Rating:
    100%
    4   0   0
    mine needed the same thing on the knock. Lund adjusted no prob. Knock sensors still just as active as ever. Something about the headunit vibration transmitting through thr bracket. I had zero doubts about it and was 100% sure it was false.
    JPSTANG likes this.
Loading...
Share This Page
