Aftermarket Mustang 2.3T/5.0 Emblems--Do they fall off in the carwash?
omelet1978
Atlanta, GA
2011 Sonata 2.0T Limited
Hi,
I'm looking at getting a 2.3T emblem for my Ecoboost. I've noticed virtually all of them are glued on. I try to take my Mustang through the carwash every couple of weeks so just wondering if they would fall off if I did that?
I'd get 2 of them for like $60 so not the end of the world if they did. Also if there is one that is screwed in I'd be interested in that since I'd put it on and keep it. Here is an example of what I'm looking at.
https://www.cjponyparts.com/upr-fen...VrVLx3xlFUf49dRJPffHwklISPXW7mohoCEHEQAvD_BwE
CorvZ061
Oxford, Ga
Travis
2022 GT
the factory 5.0 badges are taped on, no holes in the fenders, so long as you clean and prep (no wax on the paint) the surface prior to install you wont have an issue with them falling off
ORRadtech
Atlanta, Georgia
Nearly any emblem on the side of modern cars are taped on. Very few are through bolted/screwed on.
As long as you clean/prep the surface and follow the installation instructions it's very unlikely they will come off unless you intentionally try.
ORRadtech
Atlanta, Georgia
FWIW the same badges are on ebay for less money.
These are the satin black but I'm pretty sure you can find the gloss also.
Dfeeds
Illinois, US
When I did the engine swap on my old sn95 I swapped out the pony emblem to black a black "5.0" emblem (used the pushrod 302). The old emblems were also stuck on so I had to heat the old one up and used floss to remove it. New ones slapped on and didn't budge for the 8 years I had. The car wasn't in the best shape so the only cleaning it got was a touchless car wash every couple weeks.
Just make sure the surface area is clean and you didn't buy something with really cheap adhesive backing.
Farkel
Cartoon City, Nirvana
Marc
'20 GT Premium PP1, 2012 Jeep JK, 2022 Harley 48
I wanted something different, so I ordered the grille pony and 5.0 emblems in Magnetic Metallic to go on my Kona GT (no GT emblem for the back 'cuz I swapped the stock decklid panel for the Scott Drake version). Installation went fine after doing all the proper prep. A few days later, the driver side 5.0 emblem fell off on the road somewhere, leaving the tape firmly attached to the fender! Obviously, the emblem was not properly stuck to the tape. After numerous attempts to contact CJPP about replacing the defective emblem (including a PM on this forum), with no response, I gave up and ordered a new set of fender badges. They're supposed to ship tomorrow, and I'm keeping my fingers crossed that the defective one was just a fluke.
Little Guy
Houston
Kevin
2019 Mustang GT
I changed mine about a month ago. I gone to the car wash once. So far, everything is good. As others have said, side emblems are taped on but also sit is small holes. The CJPP ones sit in those holes as a guide. Take your time putting them on. That glue/tape can be difficult to get off. Make sure you have some goo be gone.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
Check Amazon. You can get oem ford emblems for a decent price on there. Why gamble with chinese garbage?
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
I had the same issue with UPR units twice, losing one on the road. Oddly, the second set I installed lost its grip only on the passenger side. That side eventually lifted again slightly, so I carefully applied some Gorilla Glue with a toothpick on the back side of the badge to adhere it back to the foam tape and it hasn't been a problem since. The foam tape always stayed firmly attached to the fender.
My take is that the badge is hollowed out on the back slightly to save a tiny amount of molding material and there's not enough surface area for the tape to firmly hold. The glue method was a crutch, but GG expands slightly from what I've seen and probably filled some of the void. Still not sure they'd hold in a car wash, but my car never gets washed and only sees a duster and detail sprays.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Don't bother with Goo Gone. It isn't going to do much. Use 3M adhesive remover. Comes in a spray can and has a #1 on it. This will save you a lot of time and reduce the amount of rubbing and scraping and chances of scratching your paint.
ChaoticFury09
Toronto Ontario
Nathan
2019 GT Premium (Automatic - Magnetic)
They are taped on but they have guide pins which I think helps keep them in place.
ORRadtech
Atlanta, Georgia
I assume you are referring to the 5.0 emblam on the GT? I'll take your word for that. But, most cars do not have indentations where emblems/ wording goes. I've worked on many makes and models and the vast majority just tape to the panel.
Besides, the OP is asking about putting aftermarket emblems on a fender that never had one so weather or not the GT has indents, his won't.
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
I put on new emblems on my GT and there is holes in the finders on each side
