Aero force scan gauge with roush vent
Niz55
Us
17 GT350
Used for 5000 miles both are in excellent condition RED. Comes with optional 5.0 face plate.
$220 shipped in us.
Jonspeed
WA
what capabilities does this have? Is it the single or dual scan one? Can you add PIDs? or Only whats on the OEM ECM?
Can you see boost psi?
Niz55
Niz55
Us
17 GT350
this from lethals website where i bough it from.
Aeroforce Ford CN Series SINGLE Interceptor Scan Gauge
The all new 2011+ Ford specific gauge from Aeroforce is here. It has several added features and support for 2011+ Fords including Ecoboost platforms. The new features include 3 new display options including a live 2 parameter scrolling graph, 4 parameter bar graph, and 8 parameter mulit-screen. It also has a peak recall feature for any parameter
The Interceptor is capable of displaying the following parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display.
* RPM
* MPH
* Intake Air Temperature
* Intake Air Temperature 2 (charge air temp)
* Mass Air Flow Sensor Counts
* Mass Air Flow Sensor (lb/min.)
* Engine Coolant Temperature
* Long Term Fuel Trim (bank 1 and 2 if supported)
* Short Term Fuel Trim (bank 1 and 2 if supported)
* O2 Sensor Voltage (bank 1 and 2 if supported)
* Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
* Ignition Advance
* Knock Retard
* Cylinder head temperature
* Engine Run Time
* Battery Voltage
* Throttle Position Percentage
* Throttle Position Voltage
* Engine Load
* Calculated Horsepower*
* Instantaneous and average fuel economy*
* 2 user configurable analog inputs**
* Injector Pulse Width
* Injector Duty Cycle
* Fuel Pump Duty Cycle (returnless systems)
* Fuel Pressure (returnless systems)
* Transmission Temperature (Automatics)
* Calculated Engine Torque
