I took a good look at the info on the website. Received a reply to my question anout how the power is increased without adding timing. The answer was a bunch od bullshit. THe reason e85 work to improve power is because it allows you to greatly increase your timing. The fuel itself actually comtains significantly less energy (btu) than gasoline, but the advanced timing more than makes up for this. But, the response i received said nothing of this.
Here is a good video comparing stock on 93, Lund-tuned 93, and Lund flex fuel.Not sure I agree about the comment of Dorace not caring about blowing her motor. Not knowing her form a can of paint but when you take into consideration the cost of the kit which is $1K versus the cost of a Voodoo engine, which last I checked clocks in around $20K, not sure she would just take that risk because she has money. The mods that she has done thus far are not overly expensive so it looks like she has a plan on what/where she is going with this build.
There is none. The Lund, and Livernois for that matter, tunes give optimal e85 results for less money and no additional hardware.As far as the method of determining ethanol percentage, Ford used to use ethanol sensors but switched to software-based when they introduced a more powerful ecu. GM still uses a separate sensor. Obviously Lund is comfortable with Ford's approach on millions of flex fuel vehicles.So what's the point of this kit when you aleardy have a tune can run e85 without this.
