I think this would just provide some convenience. Flex tunes detect ethanol percent post combustion based on O2s, so when switching between fuels you want to run down as close to E as possible and then drive conservatively while it readjusts. Then, someone could mistakenly dog it immediately after switching E85->E10 and run into dangerous knock from the timing changes. This adjusts pre-combustion and doesn't change the base tune. From the description, you just pump and go. Plus, the plug-n-play nature allows for removal in case of needed warranty work. It is more expensive though, and I'm certain gains will be lower with the harness vs the tune due to max timing.Would a custom flex fuel tune not be cheaper? And, well...custom?
