adding a factory subwoofer to base car?
mulage
Central, NC
2015 Mustang GT, Black, w/ Performance Pack
has anyone added the factory subwoofer to a base car?
i see some of the complete sub assemblies on ebay with factory amp and harness, just wonder what's involved
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
I just installed a sub in my base model. You will need an amp and a line out converter. You can wire the LOC into the rear deck speakers.
mulage
Central, NC
what kind of enclosure did you use?
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
mulage
Central, NC
got a picture of your set-up?
svtguy
Ontario Canada
2016 V6 Vert
Looks good how is the sound being controlled off the rear speakers .
What amp did you buy did it have a built in line converter?
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
I have the alpine MRXv70. It does have built in line converters but I am still using an external kicker KISLOC LOC. I was told by a few people to use the built-in converter but often times I read about people having noise issues.
The sound is controlled from the front. I havent tuned the amp and sub yet other than basic settings. I have not connected the front speakers to it yet either. I will do this later on.
mulage
Central, NC
I am gonna try one of the JL Audio powered subs, how did you guys tap into the existing speaker wires? did you cut them twist together or use something else?
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
I wish we could add a factory sub to the base audio or even premium audio. Someone tried it and found unless you have shaker pro, the harness for the sub is not included.
assclown
Warchief
GTA - Canada
Dee
2015 GT Vert
The harness would carry the signal and (low) power to the unit. Why not just run a new wire from the battery back, and tape into the rear deck?
You would have a much better signal and power supply this way. The box could tuck into the rear right corner of the trunk too.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
Well, I just hate the idea of running wires.
mustangv6magn
@mmagnetic2016
2016 procharged v6 magnetic 2016 ford eplorer
I was thinking of doing this set up I have a dB sub and a amp about the same size. I like this idea of mounting the amp on to the enclosure. So does it sound good.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
Not the cleanest set up but then again I'm not done yet
I was thinking of mounting my amp to the sub but it's a pain if you want to remove the sub. You've got to disconnect all the wiring for the amp too. I thinking I'm going to put my amp on drivers side so if I need to carry anything large I can still put down the passenger seat.
