Active Exhaust not working in Sport and Track Mode
rcald
Port Saint Lucie, Fl
Randy
20, Shelby GT 350, 20 Bullitt, 02 GT Vert, 07 Stage 3 Roush Roadster
I noticed the rumble/exhaust sound not changing when moving to Sport and Track Mode from Normal. You can hear the clicks from Quiet to Normal but not from Normal to Sport and Track. The baffle is closed at quiet, 1/2 way opened in Normal, open in Sport and Track but the sound is not there. Fuse is good, no frayed wires from the plug in an actuators (both sides which is a know issue). Any help out there?
Golgo69
Herb
2019 BULLITT
I would say it has to be the actuator. Even if the wires aren't visibly worn, there can be a short somewhere in the wire. Mine would go in and out. How many miles on the car?
rcald
rcald
Randy
41k
MiamiGT350
S. Florida
The actuators collect a lot of road debris. They may need to be cleaned out, or you could have issues with the wiring/actuators as others mentioned. Only way to know is drop the exhaust, remove the actuators, and see if your exhaust valves move easily when you turn them by hand.
Golgo69
Herb
2019 BULLITT
What he said. Especially with 41k miles. Mine started giving me trouble at 5-8k miles....It's in a jacked up position that will eventually cause issues. When you get a new (and you most likely will) just zip tie it up and try to avoid too many bends. It's very easy. You'll have no more issues after that! These
Headless Horseman
Atlanta, Ga
Tim
2020 Mustang GT PP1
I had to replace an actuator in my muffler. It got stuck with lots of pebbles and dust.
BlkMach10510
2023 Mach 1 10R80
Headless Horseman
Atlanta, Ga
Tim
2020 Mustang GT PP1
