Accurate Tire Pressure Gauge Recommendation
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Didn't know about "Accu-Gage" until you mentioned the outfit, DT but if you've had one for over ten years and it still works perfectly, that is my kinda gauge. All brass, better valves and seals are all music to my ears. I shall check them out, thanks.
Down here near the Equator, the atmosphere is quite corrosive and if a tool can keep on ticking in that environment, I'll take one. :cool:
Earl: If you have the full (truck) size version of that gauge, then I know it's accurate to within a half pound or so for sure, probably better. (The short (and plastic) versions of these type gauges are usually junk though.)
So, if we do have the same basic gauge Earl, are you wanting a dial type for more accuracy? In my old age, I can live with +/- .5 psi.
KB
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Yeah, it seems well put together, and it was less than $25, cheap and good, that's a rare combination :D
Hahaha, I hear you about "corrosive atmosphere", we're a couple of blocks from the ocean, and a couple of blocks from the intracoastal - anything sitting outside pretty much dissolves.
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
Digital, and plenty of good ones. I've found the Kobalt tire pump, the nice $50 Digi handheld, and what the car all say are within 1 psi of each other. Things nowadays are just more accurate than they used to be.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I use a Longacre analog gauge.
