cechk01
So i Know there have been a lot of issues with the AC evaporator on these cars. But I am not sure that is the cause of my issue. The AC works very well if the outside temp is about 70 or below. When it is about 75 out the AC will run for a few minutes then cut off and start blowing hot air. When it is hot out 80+ the AC will only blow hot air.
When the AC is working the air is ice cold. When its not it is the same as running the Ventilation with out the AC turned on. I have checked the AC compressor and found that the AC clutch does not engage when ever the AC is blowing hot air, which is expected.
Any ideas?
I have brought the car to ford once before for this and they were unable to replicate the issue. It was on a cooler day, just bad timing.
Is there anything I can check? My gut tells me its an electrical issue or a bad sensor telling the compressor to turn off.
Any ideas?
