If you have a 2019, in the dash cluster menu, you should be able to toggle to the gauge list. In the list you should see a readout for the trans temp (if you have a 10R80). I know the feature exists on my 2018 w/ PP and 10R80.How are you getting specific transmission temps ? Are you using a scan tool ? I only see a needle on the dash for trans temp
You need a pump with a tube. Similar to adding oil to a differential. I don't think you could get much up in there by trying to pour anything in.How hard is it to add trans fluid? Do you need a special tool/funnel or can you just poor straight in...? Obviously need a lift.
10-4. I assume something like this would work?You need a pump with a tube. Similar to adding oil to a differential. I don't think you could get much up in there by trying to pour anything in.
You definitely need a pump like FlimFlamm said. There is no room to pour from a bottle. I bought one of these for the job and it worked good. https://www.amazon.com/gp/product/B07DTS8N7P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1How hard is it to add trans fluid? Do you need a special tool/funnel or can you just poor straight in...? Obviously need a lift.
Yes exactly like that ^You definitely need a pump like FlimFlamm said. There is no room to pour from a bottle. I bought one of these for the job and it worked good. https://www.amazon.com/gp/product/B07DTS8N7P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
You should check yours ASAP, mine was half a quart low. After the fluid was added it seemed to shift better
Mine was checked via dealer some 5k miles ago. Tech said it was a beotch and had to use a welders glove to check it due to hot cat sitting next to plug. They never directly confirmed it was low or not and said they where not going to add any more...? I bet it was a tad low imo. Could not imagine adding 1/2 a quart would hurt or over fill it.You definitely need a pump like FlimFlamm said. There is no room to pour from a bottle. I bought one of these for the job and it worked good. https://www.amazon.com/gp/product/B07DTS8N7P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
