Dave2013M3
- Aug 22, 2014
- El Segundo,Ca
- 2020 Ford Mustang GT Base PP1 6MT Rapid Red
We should petition Ford into doing this.
Multiple people have already installed GT350 TR3160 transmissions in GTs.Let’s see who jumps (or has already jumped) on the grenade first to retrofit one of these into a GT.
That's the point. Ford should do this with all the lines and coolers pre packaged.You don't have to wait and hope, it's available today:
https://www.levittownfordparts.com/sku/m-7000-m8s.html
Then go buy the lines and cooler assembly separate.
Then they'd have to get engineering to do approved installed instructions - including modifications needed to make it work. I can't imagine what the jacked up price would be to make it worth while profit wise.That's the point. Ford should do this with all the lines and coolers pre packaged.
I mean I guess, but they have that it's called the GT350 or Mach 1.That's the point. Ford should do this with all the lines and coolers pre packaged.
Then there's this...That's the point. Ford should do this with all the lines and coolers pre packaged.
Except the front bumper is not ducted to flow air to that cooler on a GT. I'm not even sure there is room to bolt the cooler up inside the front fender on a GT.
There's room, the GT fender is the same as the Mach 1.Except the front bumper is not ducted to flow air to that cooler on a GT. I'm not even sure there is room to bolt the cooler up inside the front fender on a GT.
