ugstang17
Load on my current setup (11-12psi) is 1.72 at WOT at 7500 RPM on the dyno. Thats a 2300 TVS PD setup with a twin 67mm TB and JLT 125mm air intake tube. Elevation is around 480 FT above SL.
Does this indicate boost leak?Load is how much air pressure made it into the cylinder. 1.0 would mean when the valve closed you had 1 atmosphere of pressure in the cylinder.
If you have 10 PSI of boost over atmosphere in you manifold and are only getting 1.3 load, the cylinder is not filling all that well.
I dont think your load is really even getting that high. Usually load is MAF(lb/min) divided by RPM, divided by 4, divided by .00167. .00167 is the air mass in one cylinder when it is full to 1 atmosphere of pressure.
You can not trust your MAF lb/min. if you look at the MAF hertz compared to it, they rise with the same slope, and fuel trims are happy. then at ~6250 the Lb/min rise sharply but the MAF hertz does not indicate airflow doing this, you see the fuel trims go rich.
If fuel trims stayed near 1.0, your lb/min would not have been much higher than a NA car. Meaning you are not making any boost, or none of it is getting into the cylinder.
Good idea to also verify the BOV is closing properlyFrom your first log, and this latest one, I thought your BOV was not closing.
The MAF signal in this latest one looks a bit better. smoother, less choppy. Still pretty bad relatively.
Move to topGood idea to also verify the BOV is closing properly
So I added a manual boost gauge and I am getting 10-11 pounds of boost but load is still low. I have my irmc like this picture attached. If bypass valve was not working I would not build 10-11 pounds of boost at gauge correct.Move to top
Thanks for all the input guys, pulled that cap off irmc and behold load is way up in the logs.I pulled uot my advanced tuning book this morning. Calculation of theoretical fill is not that difficult. M= (Vengine)x(P air)x(RPM/2)
Density air standard is 0.00004671 (P air)
Engine Displacement is 302 CID (Vengine)
RPM - the RPM you seek to target. In this case I have used the peak RPM in the OP's recent log of 7569.
Remember that Ford calls the Coyote a 5.0L it is really 302 CID rounded up to 5.0L in the conversion. 5.0 Liters is actually 304.818 cid. This is why CID is used rather than Liters in the equation.
The theoretical fill (100%) of a 302 CID Coyote operating at 7569 RPM = 53.3857 lb per minute flow. At a load of 1.39 this equates to 74.206 lb per min seen by the MAF. The actual being seen by the MAF in the datalog is 71.95 which is well within tolerance. AFR is not going lean or being over corrected by STFT or LTFT. In fact I am jealous of how stable the STFT's are on this tune. So there are two things here you may wish to consider. 1.) It may be that Lund is scaling the values down that you are seeing in the tune in this case for some reason. Asking them about this would be the first thing to do so that you clear up the unknown. 2.) If they are not scaling then as mentioned by another contributor the IMRC plates may be restricting flow. Why your vac/boost gauge reads 10-11 (I assume that is constant and not just a peak and then settling lower on the pull) it may be tied in to a place in the vacuum system that may not exhibit actual boost being seen in the intake IDK. Again I deal with PD setups and vac/boost is picked up right on the intake.
Hope this helps you out.
