I'd like to see some doc's on this.I’ve read that newer API rated diesel oils are the equivalent of Euro A3/B4. That’s the story behind the story.
Yeah, I seen it on BITOG a few years or so ago when a few in my circle were sourcing alternative oils for their EcoBoost F-150sI'd like to see some doc's on this.
It certainly has, most of the "premium" shelf oils switched to cheaper base stocks to reduce costs since the big C. I don't really think it matters that much though, as long as it can meet the API specs it's fine. Especially for those of us on here that change every 3-5k miles, lol.Motorcraft oil sucks for protection. It shears down fast.
From some industry leaders the oil additives have gone up 100% and oil prices for engine oil have remained the same. I wonder if quality has gone down?
Had to look that one up "Polyalphaolefin (PAO) fluids are the most common major synthetic base oil used in industrial and automotive lubricants. These synthetic hydrocarbons are designed to provide superior lubrication performance over a wider operating-temperature range than petroleum oils and typically are less volatile."My understanding is GM also recommends Mobil 0W-40 ESP for track use.
0W oils most always have a higher percentage PAO base oil than 5W-10W.
My 91 FXRS and 2002 FXSTD were on the road in south Florida. My coldest start up was at Daytona bike week.I use LiquiMoly 10-60 in my HD. But I ride when most would say it's too cold.
PAO = Group VHad to look that one up "Polyalphaolefin (PAO) fluids are the most common major synthetic base oil used in industrial and automotive lubricants. These synthetic hydrocarbons are designed to provide superior lubrication performance over a wider operating-temperature range than petroleum oils and typically are less volatile."
Perhaps why many European automakers recommend 0w. Mercedes-Benz, Porsche and Volkswagen.
Not finding a difference between 0w and 5w relative to PAO base.PAO = Group IIII
The boutique blenders have typically gravitated to using a higher percentage of group IIII in their base stock blend. ie; Liqui-Moly, Amsoil, RedLine, Motul…..
For retail off the shelve non-dealer or members only available oil the 0W-XX is the most easy and affordable way to get a boutique oil base stock blend at a local retailer.
You’ll need to find and open the SDS/MSDS sheet for the oil you’re comparing. There you’ll find the percentage for the base oil “CAS” chemical abstracts service.Not finding a difference between 0w and 5w relative to PAO base.
My FXDWG is my avatar, I ride if there is no ice on the roads.My coldest start up was at Daytona bike week.
