With my slicks, I was able to clutch dump at 4500 on 2-step. I suggest those next time.
It's so much fun when you think you have something figured out, and realize you are more lost than you were before. I have learned over time to not let one track outing dictate whether something worked or not, especially when playing with a tire limited combo. Sometimes the track just plain doesn't work. Seat time, seat time, seat time.
Yes, my installer set it up with 1" fittings/tubing all the way to the intercooler.How did the EWP pump work out for you, were you able to do the 1" lines to KB intercooler. Did the IAT2 temps reduce with it and what sensor do you log for IAT2. I've read where your saying not sure the IAT2 data you were getting was real.
I also did the EWP high flow programmed pump on my whipple setup. All 1" lines and fitting even at the intercooler however the inner tubes to the IC are chocked down .625". That EWP is a monster and took a lot of creative plumbing to get air put of the system and get a clear column of water flowing.
Below is the mph log of a previous 10.1 pass. I assume the mph dips at the shifts because tires are spinning even with the 3.31's/27 inch Hoosier quick time pros(bias ply). Only had to shift twice:cheers:What slicks? 27" Hoosier? Next purchase with wheels and tires...
Yup, on 17” WeldsWhat slicks? 27" Hoosier? Next purchase with wheels and tires...
Interesting.... 60ft?Yup, on 17” Welds
Best 1.3x average 1.4xInteresting.... 60ft?
