Redline360
- Feb 21, 2018
- California
- Website
- shop.redline360.com
- Dan
- Mustang
Rev9 Hyper Street II Coilovers Ford Mustang (15-19) R9-HS2-053
Hyper-Street II coilover suspension upgrade features mono-tube shocks with 32 clicks rebound settings and full length adjustable. Mono-tube shocks provides larger capacity for gas and oil to improve comfortable level of typical lowering vehicle. Special 32 clicks of valving allows user to fine tune rebound force settings. Independent spring tension and full length adjustable allows drop without sacrifice comfort by shorten pitch distance.
- Full Steel Alloy Constructions With Aluminum Hardware
- Mono-Tube Shocks Provide Larger Capacity of Oil And Gas
- 32 Clicks of Rebound Force Adjustment
- Full Length Adjustment - Lowers The Car Without Ruining Spring Tension
- Independent Spring Tension - Custom Stiffness Without Change Ride Height
Special Notes DOES NOT fit Models with MagneRide and Shelby Models
Damping Levels 32 Levels
Height Adjustment Yes
Spring Rate(Front) 7 kg/mm
Spring Rate(Rear) 10 kg/mm
Spring Length(Front) 190 mm
Spring Length(Rear) 210 mm
Camber Plate(Front) No
Camber Plate(Rear) No
Spring Inner Diameter(Front) 62 mm (2.44 inch)
Spring Inner Diameter(Rear) 62 mm (2.44 inch)
See all Rev9 Coilover Kits
