2016S550
If I remember correctly you had a Lund tune that was working after some difficulties. Why did you transition to the FMS? ThanksI'm running the 4.09s with the Ford Performance/ProCal4/CAI/throttle body pack.
IMO, 4.09s are a completely positive change to 18+ GT manuals and WELL worth it for folks coming from the base 3.55 ratio like I was. The new ratio allows you to keep the engine in the sweetest part of the rev band in more situations without going to jail and the change just makes the car feel happier somehow.
The swap is labor intensive. If you already have 3.73s, the change isn't going to be quite as significant. That may seem obvious but it's worth keeping that in mind as you size up the job or get quotes on having it done.
Unless something has changed since last year, I don't believe this is correct. I tried and tried and had no luck with Forscan. There's something in the logic of the rev match software that just isn't fooled by altering the tire diameter.
