350/350R On a 2-Post Lift
US HWY 666
Southwest
R
Is it OK to put a 350/350R up on a 2-Post Lift using the front K-Member where the two bolts
attach it to the car behind the front wheels?
Not too enthusiastic for using the pinch welds if not necessary. It looks like I have to use the
pinch welds by the arrows in the rear, unless someone has an alternate location for the 2-Post
Lift Pads.
ZX3ST
STL
2018 GT350, Kona Blue, J3116
I wouldn't. FWIW I use the pinch welds on mine with zero issues. With the rubber pads, I haven't noticed even a scratch, much less bent pinch welds.
galaxy
St Louis
'17 GT350
The pinch welds on this car, to put it mildly, are f$&@ing robust. They will take it in strides.
US HWY 666
Southwest
R
Thanks, getting ready to get my own lift, have an R coming in soon, the dealer's lift is not
too good, super old rubber pads. Will see what happens, would like them to install the front splitter
but I can wait if I think their lift is too marginal.
I also have a set of 2" ZL1 Pads and Mag Pucks.
This is mainly a truck dealer, they are not really set up yet for Shelbys, when I got my '16 Track Pkg. 350,
wouldn't let them touch it.
ReapSow
Colorado
Adam
2017 GT350 and 1996 Cobra
I put mine on a 2 post lift all the time on the pinch welds, no problems here either.
jlauth
IN
2017 GT350
There are 2 bolts in the rear that are used when jacking rails are installed i believe. I think these are preweld assembly bolts...I typically put my jack with a rubber puck on these two bolts which are right next to the pinch weld in the rear.
NUTNDUN
Dover, PA
George
2019 GT350
Pinch welds here too. Except not in the pic I attached. It was the first time lifting it with the new lift and I used blocks of wood at the bolts you mention. After the first time I used the pinch welds the second time and was just fine and have done it that way since.
