Bonedizzle
I have a set of 2015+ 2M Fabrication Cat Deletes. These were only on my car for probably 500 miles. Going a different direction with the exhaust. Still has the weld on flange, as I used a 2011-2014 manifold rather than cutting up my stock header. FYI, the 11-14 manifold is not in the correct orientation to mount to these, you would need to cut and weld the flange in a different position.
Comes with what you see in the picture. Hardware stripped on me, so no bolts included, but your local hardware store should have what you need.
Price is 250 shipped in the lower 48.
Would sell for cheaper if you are local and can pick up in Omaha, NE.
