285’s on 19x10 rim Squared on a 2018 Mustang GT
10SpeedDemon
Atlanta, GA
www.instagram.com
Dre
2018 Mustang GT A10
I decided to post this because I was told a 285’s with a 10inch Wheel wouldn’t fit up front. The front tires actually sits flush with the fender and has a slight poke if you look from the front visit. I am going up to a 305 once I can find a good all season tire. Also I have about a inch of room from the struts
No rubbing or spacers!
Tire Info:
•285/ 35 / 19
•All Season
Rim info:
•Performance Pack Wheels Replica (Satin)
•Size - 19 x 10
•Offset: 35
Suspension:
•Eibach Sportline Lowering Springs
•Camber Bolts!
I have absolutely no camber :)
Grimace427
NoVA
2011 Mustang 5.0
I don't understand why people say this when far more aggressive setups have been done and posted to the forums over and over. I recently installed a 19x11" 305 square setup and it fit perfectly.
Why do you say zero camber? Even from the factory the spec is -1 to -1.5 degrees up front and about the same in the rear.
TomcatDriver
Mojave Desert
2017 GT350 Magnetic w/black stripes
Tire Info:
•285/ 35 / 19
•All Season
Rim info:
•Performance Pack Wheels (Satin)
•Size - 19 x 10
•Offset: 35
Suspension:
•Camber Bolts!
Pics?
10SpeedDemon
10SpeedDemon
Atlanta, GA
www.instagram.com
Dre
2018 Mustang GT A10
its -0.8 which is in the green and basically barely any camber
ronnieb1958
Inglewood, Ca
Ronnie
2015 Ecoboost Premium
Tire Info:
•285/ 35 / 19
•All Season
Rim info:
•Size - 19 x 10
•Offset: 35
Suspension:
•Camber Bolts!
what brand are those Replica Performance Pack Wheels? I haven't found any brand who made a 19x10 for the front without s spacer.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
If not mistaken you have 2 options.
1. Is factory reproduction
2. is American Muscle.
moodywizard
Socal
Lyle
2015 Mustang GT Premium PP1
Wow, those are a steal at 130ish each.. Any idea on the weight?
Turbolag87
Toronto
My18 gt
curious on weight as well.
Kevin08
Panhandle FL
Kevin
19GT
19x10 is arguably the most common aftermarket wheel size for squared setups on S550s, whoever said that wouldn't work is retarded or using a ridiculous offset.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
anyone else put a rear 19x10 wheel on the front?
If it's +40 to +35 offset, it will work. A +45 offset wheel with a 5 mm slip-on spacer would be fine too.
