(276 rwhp) How to install a ProCharger on a 2018 Mustang !!!!!
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
Chris Barnes
Arizona
2021 GT500
Great Article! What spark plugs does ProCharger recommend for the 2018 GT with a Stage II Kit? I picked up a set of Brisk RR14YS, but I've seen some people running the NGK 6510's. I originally chose the brisk because I recently read the silver is a better knock deterrent than the iridium or platinum? Thanks!
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
oh no!! no OPG!!! lol man this make me want one. just need to save a few more K
Draklia
Dry Land
2017 GT
Yep, works with factory oil pump gears and catalytic converters. No risk at all just like all the other FI kits. Bolt it on, redline the piss out of it and don’t worry about a thing.
ProChargerTECH
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
We just normally use the 6510's since we have a lot of them in stock.
However, we have also heard great things about the Brisk.
No fuel system changes, no injector changes. Just loads and loads of HP. :)
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
this is the first i heard of this. most setups i have seen require at least injectors and a BAP..
bluestang50
GA
2017 F150, 2020 Explorer ST, 1990 Mustang GT turbo
The article shows them installing a BAP in the trunk. step 21
beefcake
Bethel
2018 Ford Mustang
i would do at least a bap, but around 600 wheel can be accomplished on the stock injectors
ProChargerTECH
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
Well it does have a BAP if the kit is a STG2. (The HO does not)
Though I meant, it doesn't require injectors, or line changes or anything annoying.
BrianH87
Pittsburgh, PA
2020 Mustang GT ; 2021 Explorer ST
Great info! I did read that article. Would it be possible to get a copy of the factory install guide for a HO kit in PDF? I had a TVS on my last Mustang, but thinking about going centri this time around. Please PM me if that is possible.
ProChargerTECH
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
Send an email to [email protected] and they will gladly get that PDF out to you. :)
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
What's the rev limiter set to not changing injectors?
ProChargerTECH
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
The injectors don't have much to do with the revlimiter.
But 7,400 is the limiter on the kit as its shipped.
Custom tuning can obviously change that as needed.
markmurfie
Hawaii
Mark
Just thinking if the stock injectors were getting close to max duty cycle, a lower RPM limit would be a safe way to ensure they don't max out. Cool to see that's not the case with a Procharger kit.
ProChargerTECH
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
We also run a lower boost number then most (8.5) so the delta pressure is different then something running more.
