Moving back here so I don't hijack the F1 thread. You have a very good point about Eau Rouge/Raidillon. I am a bit biased, because I've walked Eau Rouge and looked at it from every imaginable angle. But, then again, I feel like I've accomplished something when I'm at 160-180 kph and can't imagine taking it at 250.did you watch the F2 incident with Hubert ?
Did you watch the incident from 24 hours of Spa ?
Both of them were because a car crossed the runoff on Eau Rouge and stopped on the straight where other cars can't see them both of them were cars on the straight after hitting a barrier this shouldn't happen. If you hit a barrier and you have sand there is no way you are going back at the track. Hubert hit the tire wall at Radion and got back on the track and got collected by another car at 250 km/h if track safety is good this shouldn't happen. I'm just saying that Eau Rouge / Radion is to dangerous as is with modern day cars running full blast through it in racing.
if it was easy then anybody could do it. The point is that it requires skill to negotiate. Doesn't mean there should be walls and insufficient run-off in case of a screwup though.the only way I can think to change it would be to straighten Turn 4--take the kink out. Then it would be more of a straight uphill shot between turns 3 & 5.
