Kreasen
- Dec 9, 2024
- south africa
- Kreasen
- 2016 Ford Mustang GT, 2021 Ford Mustang GT
Just made the changes in ForScan. The Axle Ratio was set to 494.xxx which seems odd. I adjusted it to 4.09 so we'll see what happens in e next 30 miles.
On Forscan should it not be 4.090 as apposed to 4.09.
I did an axle swop from 3.55 to 3.31, I was having an issues where the car would have no power in 3rd gear around 2-3000rpm
I was able to successfully change the axle ratios using Forscan.
First I updated the BCM with the new ratio, and then performed a PCM relearn.
One other thing to note when I read the axle ratio using forscan it said 3.550 so I updated it to 3.310
