2022+ Carbon trap- A word of caution
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP, 2023 F150 Powerboost
Just thought I would share a little info on an issue I ran into while getting E85 tuned by @Wengerd Performance. To be very clear, this issue had nothing to do with his tune, and Darryl has been more than helpful, responsive, and the car is transformed on his E85 calibration. Anyone on the fence about going with Wengerd and E85- Just do it.
The day I brought my Mach 1 Home, mod #1 was to remove the carbon trap/restrictor from the intake to get my 10HP back that Ford stole from me. A simple 10-15 minute job, and put the intake back on the car. I drove it this way for about 2 weeks before getting the tune, and never noticed any change in performance but wasn't experiencing any loss of power, drivability issues or anything like that. I just figured, meh 10 HP wasn't going to make a noticeable difference anyway. (At this point I did not have any way to log, as I was still waiting for my RTD+ to show up).
As it turns out, after working with Wengerd it became apparent that something was amiss. The car would not idle correctly. When coming to a stop, any time I put the clutch in the RPM's would climb to about 2500 and then after about 5 seconds return to normal idle speed. The behavior was mimicking a vacuum leak or maybe a bad Idle Air control motor. After sending some logs Mr. Wengerd noticed that my fuel trims were hovering around +20%. So, either I had flashed a gas tune with E85 in the tank, or I had a leak somewhere (or so we thought)
Long story short- If you want to remove the carbon trap from the intake, you need to separate the filter portion from the fluted section, and then put the fluted section back in. The issue here was that by removing the entire assembly, this increased the inner diameter of the intake tube, which of course threw off the MAF readings. After thinking about what I had done, and scouring over the intake piping, throttle body, intake manifold etc. for leaks I had a light bulb moment and realized what had happened. Pics attached of the pieces.
If you leave the fluted sleeve section out, your gonna have a bad time.
simply separate the round filter potion from the sleeve, then put the sleeve back in. You can see where it fits around the MAF Sensor, and clearly reduces the size of the intake tube. Perhaps this issue has already been discussed, but just thought I would share incase anyone else wanted to do this.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Before your tune. You only discovered a problem AFTER the tune.
So to sum up:
Before the tune you never noticed any problems.
After the tune you noticed a problem.
But I ain't no rocket scientist.
NGOT8R
Adrian
2019 Bullitt
I had a similar problem with my PMAS (no tune required) CAI. Idle would hang when coming to a stop just as you required. Lund to,d me it was cause by turbulence from the PMAS and it was not tune related. I kept driving the car and after a while it worked itself out.
2022 Mach 1
Brentwood ca
Cameron
2022 Mach 1...2014 Mustag GT whipple supercharger
It's funny that the removal has been covered ad nauseum and everyone talks about replacing the tube
SheepDog
SheepDog
Colorado
Dax
So to sum up:
The combination of the higher fueling demands of the E85 calibration, in addition to the slightly larger diameter of the intake is what brought the problem to my/Our attention. As the change in diameter was not very significant, running the factory calibration on gasoline didn't throw off the fueling enough to cause any drivability issues or throw any Check engine codes.
Wengerd Performance
Gold Sponsor
Paris, Tn
wengerdperformance.com
Derel
18 GT Whipple 15 Mustang GT TT 18 F150 VMP ODIN
We can calibrate the maf for this removal but even on pump gas on your stock tune you still would have had close to positive 20 percent fuel trims. I am surprised you didn't Have lean codes come up.
SheepDog
SheepDog
Colorado
Dax
We can calibrate the maf for this removal but even on pump gas on your stock tune you still would have had close to positive 20 percent fuel trims. I am surprised you didn't Hage lean codes come up.
Im sure it would only have been a matter of time. I didn't drive it much in those couple weeks. Thanks for all your help, the car runs great. !
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Yes I already gathered all that.
20% won't trip a lean code.
If it didn't trip say within 50 miles of driving, it won't trip.
SheepDog
SheepDog
Colorado
Dax
how did you remove the tube from the intake ?
There are 3 tabs that all need to be pried inwards simultaniously, I used 2 pocket screw drivers and a straight pick. You can see them clearly in the first image. same process to remove the carbon trap from the tube itself, then just snap the empty tube back into the intake
