2021 Mach 1 Mustang Prototype Spied on The Prowl?!
Discussion in 'Mach 1' started by Jarstang, Jan 24, 2020.
  1. martinjlm
    martinjlm Retired from GM
    Vehicle(s):
    2017 Camaro Fifty SS Convertible
    Feb 4, 2018
    Detroit
    1,461
    1,579
    0   0   0
    #226 martinjlm, Apr 8, 2020
    The two things are not mutually exclusive, but at this point I’d say this is low probability. Such a vehicle would outperform GT500 in some key measures (0-60, braking distance) and would just add additional expense. Ford is not gonna go there (PP2 / GT350). I expect a 5.0L Coyote, maybe Atkinson Cycle operation, paired with a 40 - 50kW electric motor mounted coaxially between the engine and the torque converter. And a 1.3 - 1.8 kWh lithium ion battery located under the rear seats.
    EDIT: I may have to notch up the potential for the front axle e-motors based on info @Twin Turbo found in Autocar (a very reputable source in the UK) suggesting exactly that. It references a Ford patent that shows a V8 with provisions for front axles passing through the lower crankcase on the V8. I’ve also seen that patent before but assumed it was for F-150 hybrid. At this point, we’re calling the F-150 Hybrid a 3.5TT, so the only other place that V8 can go is Mustang.
    Twin Turbo likes this.
  2. Semp1
    Semp1 Well-Known Member
    Vehicle(s):
    2018 Mustang GT PP1 Magneride
    Apr 26, 2019
    NYC
    344
    80
    0   0   0
    The mach1 will not in any way shape or form be electric. Quote me in 6 months.
  3. Semp1
    Vehicle(s):
    Apr 26, 2019
    NYC
    344
    80
    0   0   0
    That technology will be saved for the S650. There’s not a strong possibility at all.
    martinjlm likes this.
  4. Schwerin
    Schwerin Well-Known Member
    Vehicle(s):
    2019 Mustang BULLITT
    Jan 31, 2018
    Philly
    2,305
    1,068
    0   0   0
    It could be if they want a low volume mule to try on before going full production for the S650.
  5. Semp1
    Vehicle(s):
    Apr 26, 2019
    NYC
    344
    80
    0   0   0
    Ford is not about to release a Mach1 that is a V8 hybrid electric, which would most likely make it faster than a gt500 or even comparably close. You guys understand Ford already said the S650 will have the electric technology. Ford isn't going to "surprise" people with a new S550 to that extent and in return also ruin their S650 reveal features. You will most likely get a Mach1 with a manual and auto transmission option since the prior Mach1 had those options and that's it. It will be an appearance package and maybe 20-40 more hp than what Is currently offered in a mustang GT. The auto option is what's going to give it, its great times. You figure 490-500hp with the 10R80A you're lookin at something very close with 0-60 times to mid 3's with the right tires. Mark my words nothing more than that. Just an opinion take it for what its worth.
    White_GT_CS and EcoVert like this.
  6. Stymee
    Stymee Well-Known Member
    First Name:
    Joel
    Vehicle(s):
    2019 Mustang GT
    Mar 19, 2019
    Philadelphia, Pa.
    2,811
    1,255
    0   0   0
    interesting
  7. Stymee
    First Name:
    Joel
    Vehicle(s):
    2019 Mustang GT
    Mar 19, 2019
    Philadelphia, Pa.
    2,811
    1,255
    0   0   0
    I’d love to see the DCT in it but at 20k for that trans it wont happen, price the car too high
  8. Schwerin
    Vehicle(s):
    Jan 31, 2018
    Philly
    2,305
    1,068
    0   0   0
    There is a very wide performance range between GT and GT500. They don't have to make it as fast as a GT500 to make it easily faster than a GT.
  9. EcoVert
    EcoVert Well-Known Member
    Vehicle(s):
    2015 Ecoboost convertible
    May 28, 2016
    W.VA
    3,383
    1,720
    Garage Profiles:
    This my thoughts also the Mach 1 will be an uprated version of the Bullitt with all the Mach 1 visuals and more HP.
    Stymee likes this.
  10. v8hgt
    v8hgt Well-Known Member
    First Name:
    Nick
    Vehicle(s):
    Race Red GT PP Coupe
    Mar 31, 2016
    Cheshire, UK
    981
    299
    Garage Profiles:
    Hasn’t this patent been detailed before on these forums many months ago?
    Let’s not forget that companies patent many designs that never come to fruition. The concept behind this patent applies to the tt v6 and the i4 blocks let’s not forget. The V8 element may be somewhat outdated. The new 7.3 big block could receive this tech in trucks where it offers an elegant and efficient 4x4 when needed function.
    It appears the motors are mounted at sump level in this pic with the centreline just after the exhaust port of the foremost cylinder. I’m not going to get under my car to check but I would suspect that would put the driveshafts below the wheel centre on an s550. However in a f150 with its higher engine mounts it may well be perfect.
  11. Stymee
    First Name:
    Joel
    Vehicle(s):
    2019 Mustang GT
    Mar 19, 2019
    Philadelphia, Pa.
    2,811
    1,255
    0   0   0
    It will never be a 7.3
    EcoVert likes this.
  12. Zelek
    Zelek Well-Known Member
    First Name:
    Vehicle(s):
    2017 Mustang GT Premium PP, 2018 Honda Accord Touring 2.0T
    Feb 11, 2016
    Austin, TX
    2,709
    1,388
    Rating:
    100%
    2   0   0
    Really hoping the Mach 1 is going to be worth it. I've had the itch to upgrade to a 10-speed and one of the newer Mustangs with magneride. Option 2 is boosting my 17 GT. If they do a PP2 level with a power bump, suspension tweaks, and the other Mach 1 goodies that separate it from a regular Mustang, I think I'd bite and order one.
  13. SINBUSTER007
    SINBUSTER007 Well-Known Member
    First Name:
    Brian
    Vehicle(s):
    2019 Edge ST, 2017 Escape, 2012 Boss, 2015 GT, Powerwheels boss 302
    Oct 5, 2014
    Hagerstown, MD
    510
    227
    0   0   0
    have to see what actually comes out and how much. i want another mustang, and still looking for a Clean, low mileage 2004 Comp Orange Mach 1, but depends on what shows up first i will decide if i am going for the new Mach 1 or will still try and look for the 2004.
    wife said that since we have 2 already we cannot buy 2 more. budget will not allow. so either new or old.
    if the 2021 Mach is offered in the Twister Orange that will be the color Choice. if that color is not offered then might make my choice easier to which one to buy.
    patiently waiting.
  14. Stymee
    First Name:
    Joel
    Vehicle(s):
    2019 Mustang GT
    Mar 19, 2019
    Philadelphia, Pa.
    2,811
    1,255
    0   0   0
    500HP/DCT/PP2+
    Shaker/Unique Wheels & Body panels
    Price it in the mid 50’s
    Mikepol2, Twin Turbo and Zelek like this.
  15. EcoVert
    Vehicle(s):
    May 28, 2016
    W.VA
    3,383
    1,720
    Garage Profiles:
    I like how you think but I can't see the DCT unless the car is 60+.
    martinjlm and Twin Turbo like this.
Loading...
Share This Page
