2020 Shelby GT500 eSourceBook
Shelby GT500
Tampa
Mustang
Anyone notice the Base model tires are now listed as 295 front and 305 rear? (Page 32)
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
chill66
Reno, NV
2020 Twister Orange GT500
One of many mistakes that will probably be found.
Are you saying the base does in fact come with 305 fronts and 315 rears? I hope you're right!
mrbillwot
Greater Boston Area
Bill
'19 Kona Blue w/blk roof & blk stripes GT350, 89 LX5.0 Sedan (Mustangs Past: 69's Coupe, Mach 1, & GT)
Yes, I have 5 of them with a combination of around 400+ songs. A Big Thank You goes out to you and others. As I've said before you guys are great!!!!!!!
Chuck, You said SD cards earlier, not USB flash drives, hence the confusion.
Anyway you should copy your files (it takes less than a minute) to one drive and be done with it.
Swapping them just forces SYNC to reindex for no good reason given today's cheap storage and with one you can stay focused on driving rather than fumbling with USB drives.
I have twenty thousand high bit rate music files on mine and it will hold twice that - all on a $30 256GB stick. As long as you leave it in it doesn't have to re-index after the 1st time (that's with my Sync2 SUV...as for experience with my SYNC3 B&O setup...well I can report on next week when the Shelby is in my hands - yes, I have a play list for this event after 9 months since ordering...though I'll let the music of the engine be the headliner).
Here's the nice low profile mem stick I use (picture):
Amazon $29.99 SanDisk 256GB Ultra Fit USB 3.1 Flash Drive - SDCZ430-256G-G46
Snoopy49
California
Earl
Yes, that's a fact. It's printed on your Vehicle Order Confirmation.
DB83
Granny Shifter
Spain
2017 Mustang GT
Anyone notice the rear brakes are smaller than the GT350? 14.5" vs 15"
I wonder if it's because the car has a lot more front bias compared to the GT350
shogun32
Northern VA
> Forged-aluminum pistons and forged-steel I-beam connecting rods
Cryo-treat? Fractured? How about a material reference like 4340 Chromoly?
> Precise boring in the aluminum engine block
I wonder if they went back and figured out how to unstress the block so they don't end up with ovalized bores upon assembly. (cue, the Voodoo high oil use problem)
> PTWA liner provides an approximate 8.5-lb. weight savings over typical iron-sleeved aluminum block
I seriously question if such a weight savings is worth the huge expense and "unreliability" of the resulting bores when the tried and true solution has worked and worked plenty well enough at scale. What's the $/gram I wonder.
> With the Carbon Fiber Track Pack added, ... 550 pounds of rear downforce at 180 mph
> The 'handling package' "swing" yields 379 pounds of rear downforce at 180 mph
How about at more sane speeds of 50, 80, and 130 which is what you see on a road course?
By comparison the 911 GT2RS generates 992lbs at approx same speeds whereas the 'plain' GT2 is somewhere under 500.
> If the engine overheats, it will switch from normal all-cylinder operation to alternating-cylinder operation
Why not do this during light throttle loads (eg. cruise control) to save gas? Granted they would need to not repeat GM's "trans shudder".defect.
> 3.73:1 rear-axle ratio
that's going to make it difficult to get the power down, me thinks.
> Adjustable shock mounts only with CFTP
Good grief, they are only about $400 a pair. Should be standard across the entire Shelby lineup.
> 251 lbs./in. front and 914 lbs./in. rear spring rates
The front seems low to me with all that weight.
likeaboss
likeaboss
Baltimore, MD
2020 Corvette Z51
PTWA has been in Mustangs since the 2011 Shelby GT500, technically even earlier in the 2009 Nissan GT-R and is proven tech.
shogun32
Northern VA
when done by people who are not Ford, apparently.
I wasn't nit-picking the coating per se but rather the apparent inability for them to bore them to proper tolerance nor maintain shape. What good is a fancy-pants coating if you can't even get the machining right? Saving 8lbs is pointless on a non-moving part when they just added 400lbs to the car.
Andrewg
Sun, Sea, Sand and Camels
Dubai, U.A.E.
Andy
2015 Guard Metallic GT 401A
Was there such an esourcebook document for the MY19 GT350?
Yes. There’s one for every Ford vehicle produced in North America, every model year.
mrbillwot
Greater Boston Area
Bill
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
I finally managed to get through the esourcebook and learned a few things. But one statement caught my eye and I couldn't figure out if it was a mistake or that I was missing something since the car does not have an option for a HUD.
Here's the section from the book with the statement highlighted.
Any ideas?
mrbillwot
Greater Boston Area
Bill
Any ideas?
Isn't that just this (same as GT350)?
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Mr. Bill: Thanks for the post and the info. But the car in the video isn't a 2020MY as it has the old double tach and speedo, not the 12" LCD. But aside from that, am I to believe that the "shift light" is in fact projected on the windshield much like the "emergency stop row of red lights" in my '18 F250? If so, I like the idea a lot although I was very much hoping for a GM-style HUD.
chill66
Reno, NV
Yes, the shift light can project onto the window and has multiple configurable modes. The GT350's have had this feature since introduction.
