Tob, I look forward to your findings on clearance and ride quality.And I had to share this one showing the rotors I dressed by hand and the ceramic coating I put on the wheels and brake calipers, all Adam's stuff.
It ended up at 1/16” toe out and I left it there.Very nice. I'm a huge fan of all things MM and have used their plates on all the other Mustangs I've owned that I put springs on. They are indeed much better than the OEM plates. I just used the factory ones to see how well they worked and they did the job. Were I making constant camber changes for street to track and back I'd absolutely have used MM's.
What toe did you go with?
Are those Steeda brake lines?Steeda rear sway bar and braided brake lines installed.
That’s where I bought them. But the label says Goodrich.Are those Steeda brake lines?
you do both front and rear?
ThanksThat’s where I bought them. But the label says Goodrich.
I did front and rear.
The GT500 brake lines look like stock Mustang parts. So I figured those marketed for the Mustang would fit.
Steeda part number = 555 6027
Did you just go to ford and order the springs? Do you mind me asking how much they are?Finally got around to taking a pix of the before & after with CFTP springs installed:
Here’s the numbers (Before/After), measured at the peak of the fender though the center of the wheel:
LF
Fender: B: 28.75” A: 27.75”
Camber: B: .5 degrees A: 2.1
RF
Camber: B: .5 degrees A: 2.0
LR
Fender: B: 28.25” A: 27.5”
Camber: B:1.3 degrees A: 1.8
LR
Fender: B: 28.5” A: 27.75”
Camber: B: 1.4 degrees A: 1.9
Net affect: front dropped 1” on both sides and the rear dropped 3/4” on both sides.
Front Camber is set to max and ended up near track setting (which is what I wanted).
I added a 5mm spacer between the front wheel and the brake rotor to ensure the wheel rim does not contact the front strut with the higher camber settings.
The ride seems to the same to me. No harshness at all.
Looks like I bought the rears from White Bear Lake & Tasca (one side each — they were hard to find back then....). Receipt for the rear springs shows $153.29 each shipped with tax included. Fronts were about $50 each. They were cheaper than the rears as the rear springs are unique.Did you just go to ford and order the springs? Do you mind me asking how much they are?
